Best way to remove old engine gasket material?
Old Jul 23, 2006 | 02:13 PM
vmax84's Avatar
Pulling my 4 cylinder engine apart on the 89 4runner, and was wondering what the experts use to remove the old engine gasket material?
Thanks.
vmax84
Old Jul 23, 2006 | 02:18 PM
mtsumedi's Avatar
I use an air rotary tool with a soft wire spinning brush to remove it. Does not scar the surface and cleans it pretty well. Has to be soft enough that you could take your thumb or finger and rub across the wires and it won't hurt.
Don't try to use a Dremel, you need like an air tool or something that is a little larger.
EDIT: Oh yeah, spray the finished surface with some brake cleaner to clean off any kind of gasket particles or oil residue.
Old Jul 23, 2006 | 03:06 PM
seanz0rz's Avatar
Guest
i always used a gasket scraper, which is a razor blade with a screw driver handle.
maybe that was wrong, but always worked for me, just be really really careful not to gouge the surfaces. just go real slow and easy, also soak any material that is hard stuck on with brake cleaner or the like.
Old Jul 23, 2006 | 03:07 PM
95RunnerSR5's Avatar
when you are done getting it off, use acetone to get it absolutely clean
Old Jul 23, 2006 | 03:28 PM
Elton's Avatar
they make rubber gasket scrapers and sanding wheels for soft metal
Old Jul 23, 2006 | 04:55 PM
vmax84's Avatar
I wonder if it would be easier to get at everything if I pull the engine. I'm replacing everything in it. Should just pull it.
vmax84
Old Jul 23, 2006 | 05:04 PM
vmax84's Avatar
Here's the hog we're working (still) on:
vmax84
Old Jul 23, 2006 | 06:16 PM
mtsumedi's Avatar
That thing looks really nice. I can't wait to get mine back on the road.
Old Jul 27, 2006 | 03:08 PM
4runnerx3's Avatar
I use gasket remover. It comes in a spray can. It really works to loosen and disolve stubborn gasket material.
Old Jul 27, 2006 | 05:33 PM
toyaholic's Avatar
an old pro showed me how to hold a razor blade at a 90 degree angle and scrape back and forth. works great and doesn't gouge the surface.
Old Jul 27, 2006 | 05:54 PM
rngrchad's Avatar
Like stated before. The easiest, and quickest way is to use some 3m light abrasive pads or ro-loc discs and put them in a 1/4" air grinder. BAM, quick work and it turns out perfect every time. I do it everyday at the dealership I work at. If you don't have air tools well......the razorblade is really a pain in the butt, but it works.
Old Jul 27, 2006 | 05:57 PM
DirtCheap's Avatar
I've been working on cars and bikes for more than 30 yrs and what I, have always used is a wire brush on a cordless drill followed by carb cleaner or brake cleaner. I, can clean a complete engine in aproximately an hour.
Old Jul 27, 2006 | 06:18 PM
RustBucket's Avatar
Razor blade to get the big chunks off, then a whetstone with some solvent as lube. Gets you a nice shiny metal surface.
Old Jul 27, 2006 | 06:36 PM
vmax84's Avatar
This place is such a mountain of knowledge! Thanks again.
vmax84
Old Jul 27, 2006 | 08:04 PM
all_terrain17's Avatar
That truck looks like it just rolled off the dealer's floor. wow.
Old Jul 27, 2006 | 08:54 PM
frodin1's Avatar
Here,here on the 3M pads & angle grinder!
Old Jul 27, 2006 | 09:24 PM
LOCKnGO's Avatar
Cookies +1
Old Jul 27, 2006 | 10:22 PM
kyle_22r's Avatar
i use a hardened steel gasket scraper. sort of like a chisel with a long handle, but the edge is very sharp. it's nice because it doesn't flex and catch on water passages and imperfections like a regular razorblade scraper.
Old Jul 28, 2006 | 02:53 AM
vmax84's Avatar
It's amazing how things have gotten out of control with this truck. It ran good, however, the engine was loud. Camshaft was bad. Evidently the previous owner used it to tow his Airstream trailer or something.
So it goes from "just replacing the camshaft" to "let's pull the engine and rebuild it".
I really want to do the engine "right", since there is zero rust on this truck anywhere.
vmax84
http://community.webshots.com/myphot...ecurity=xzfUYN
Old Jul 31, 2006 | 07:55 AM
rngrchad's Avatar
Originally Posted by LOCKnGO
Cookies +1
Cookies
gotta love those 3m cookies, however they don't taste so good......
