Will a Helicoil be a perminent fix on a rocker arm?
Old Jul 27, 2006 | 01:57 PM
GrizzlyNC's Avatar
Is a Helicoil an acceptable perminant fix for a striped thread at the end of a rocker arm where the valve adjustment screw go's in? Will this give issues later? This is on a 22RE rocker. The vehicle is needed and I have been told by 2 local people that this would work just fine.. but I'd appreceate feedback from you guys.. Thanks in advance
Old Jul 27, 2006 | 02:33 PM
Chuki's Avatar
How'd you strip that out?
I think your best bet would be just to get another rocker arm, shouldn't be that expensive.
Old Jul 27, 2006 | 05:00 PM
GrizzlyNC's Avatar
Wasn't me.. was the mechanic installing my new 22RE.. I'm pretty sure it wasnt shiped out that way. lol.. the whole top half is new high performance items.. so I know the rocker setup was NOT a used one that may have had damage.. I looked at the engine myself after it arived.. It's every thing the builder said it would be built as... I will be getting a new rocker arm. but in the meen time I need the vehicle.. So.. the mechanic said they can Helicoil it and that should be a fix. I'm just curious since I know this bolt had a dynamic load versus a static load on it (Movement versus constant pressure)... I just want to make sure if this is a strong enough fix for now. My problem with it is... Now that the engine has been heated up and run in, the head gasket has not had a chance to seal up.. If the head bolts have to come off to get thet rocker assembly off then I know that will probably weeken the current gasket and cause a future failure. Otherwise they will have to go as far as taking the head off and doing the gasket all over again, just to put on a rocker arm... Sigh.. This whole thing's got me SO pissed..
Old Jul 27, 2006 | 05:13 PM
waskillywabbit's Avatar
Make the mechanic provide you a loaner and/or agree to fix it ASAP and bum a ride or rent a car. Fix it once, fix it right IMO.
bigjstang
Jun 2, 2025 03:56 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
razorman8669
Jul 12, 2015 12:13 PM
ptb12
Jul 5, 2015 01:49 PM
