code reading, injector cleaning, etc questions
Old Jul 19, 2006 | 05:07 AM
KF_Chris's Avatar
I will start by apologizing if any of this was covered recently...I've been reading a lot on the site (which rocks) and didn't really find what I was looking for.
I bought my truck wrecked (I think it was a 4X4 toy of a friend of a friend). Damage to the passenger front (bumper, fender, grill, etc) and it steers wierd. Has no power at all, I mean NO POWER. and it clatters and makes lots of noise when I drive it.
Last night we changed the plugs, wires, cap and rotor. nothing changed at all as far as the motor's concerned, but I feel better knowing those beat up parts are off the truck.
We checked for front end damage and found the passenger tie rod end and bearing are way damaged, which I will replace and get an alignment.
The steering box was loose and my friend told me (prior car mechanic for 5 years) that you guys on this site might know of an adjustment to get it back tight again.
It's throwing a code, but autozone won't read it because it's too old. Is there a way to get the code read for a decent price? I'm going to start with fixing that, then try a valve adjustment and cleaning the injectors and replacing the injector O-rings.
Injector cleaning question: I have an ultrasonic parts cleaner here at work and low pressure air lines (up to 140 psi). The parts cleaner has Mineral Spirits in it, but can I submerge the entire injector in that fluid? or none at all?
I'm hoping I don't need a rebuild, but I will understand if I do.
Any help on any of these problems would be greatly appreciated.
This site rocks!
Old Jul 19, 2006 | 05:11 AM
Churnd's Avatar
Which engine does it have? There are code readers to be had for some models.
Old Jul 19, 2006 | 05:13 AM
KF_Chris's Avatar
damn, I knew I forgot something. it's the 3.0 3rze (something like that).
Old Jul 19, 2006 | 05:16 AM
Churnd's Avatar
Check out the 3rd post:
https://www.yotatech.com/forums/show....0+code+reader
If you don't have a Haynes Manual, post the code here and somebody will look it up.
Old Jul 19, 2006 | 05:25 AM
4Crawler's Avatar
Code reader information is available here:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
You can try tighting the adjuster nut/screw on top of the steering box. Also, have someone crank the steering wheel back and forth (just to the point the wheels begin to move) while you poke around underneath watching the steering linkage. Watch for the point at which things stop moving and that is where the play is.
KF_Chris's Avatar
thank you for the referral in that link, I'll do that tonight
Old Jul 19, 2006 | 05:26 AM
Potomacduck's Avatar
Does Florida require emissions inspections? Maryland does, for the price of a fourteen dollar inspection hookup they can read all my codes on a better machine than my mechanic owns!
Old Jul 19, 2006 | 05:29 AM
KF_Chris's Avatar
nope, FL doesn't care what comes out of your tailpipe I guess.
Old Jul 19, 2006 | 07:15 AM
86SR522REEFI's Avatar
Thats the good thing about Florida. You can have a beat up car and still drive it. I know if i moved to another state that did emmisions tests that I would most likely fail.
Old Jul 19, 2006 | 07:33 AM
KF_Chris's Avatar
yeah, my bikes would fail too, with the pipe work I have done.
I read the long thread about the SEAFOAM cleaner, I'm gonna try that stuff today after work...hopefully O'Reily's has it.
Old Jul 19, 2006 | 08:10 AM
Churnd's Avatar
That would be a good combo with cleaning the injectors. Seafoam it, then clean the injectors. I'm not sure if they can handle being soaked in Mineral Spirits, though.
Old Jul 19, 2006 | 08:27 AM
KF_Chris's Avatar
noone seems to know what's safe. maybe use a can of seafoam on the injectors??? for cleaning by hand?
I'm also thinking about resetting the timing to make sure that's good, and maybe doing the timing belt. also want to make sure that the valves are gapped right. anything else I should to that I don't know about?
Old Jul 19, 2006 | 01:59 PM
KF_Chris's Avatar
some pics of the ride. I'm assuming that there's a user gallery but I'll put these here for now.
Old Jul 19, 2006 | 02:01 PM
KF_Chris's Avatar
this last pic is of the hose that I put the seafoam into, progress to be posted later.
Old Jul 21, 2006 | 06:49 AM
KF_Chris's Avatar
so my check engine light came back on. I searched (really I did) in this site and can't find anything on what to jump, and where, for reading the codes. also couldn't find the section in the Haynes where it has what the codes mean. I'm getting tired of driving such a gutless truck. no power and HORRIBLE gas mileage. the SEAFOAM didn't do anything to help me at all.
Old Jul 21, 2006 | 08:36 AM
TNRabbit's Avatar
Try this link: http://www.off-road.com/toyota/tech/codes/index.html
It is a really good explanation of how to check the trouble codes on OBDI compliant vehicles.
Old Jul 21, 2006 | 10:35 AM
KF_Chris's Avatar
thanks, I'll check it out today
Old Jul 23, 2006 | 09:13 PM
workinprogress's Avatar
reading codes
all you have to do is hook a jumper wire from the 'TE1' terminal in your diagnostic connector,to the 'E1'terminal.turn the key to the on pos. and the chk. engine light will flash the codes in a series of 'blinks'.get yourself a haynes manual and look towards the end of the emmisions chapter to find details on how to do it,and how to read the blinks.
Old Jul 23, 2006 | 11:45 PM
TNRabbit's Avatar
Save your money on the Haynes manual and just go burn a $20 bill. There is a factory service manual for a 1993 posted online:
http://personal.utulsa.edu/~nathan-b...fsm/index.html
which will work for you. If yours is a different year it will practically be the same on most all the sections.
Old Jul 26, 2006 | 03:11 PM
LOCKnGO's Avatar
This needs to be made a sticky! THe FactorySeriviceManual
Yota.Jay
Jul 23, 2015 08:08 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
smiley52
Jul 11, 2015 05:16 AM
karbin
Jul 5, 2015 11:37 PM
