88 3.0 will not start
Old Jul 20, 2006 | 06:49 PM
m1ke_w1nn1e's Avatar
I've been fighting this thing since Dec and P.O'd the local Toyota dealer so I really could use your help. I did search but could not find anything with what I know is going on with this thing. (or not going on)
I will list out some quick details that I have checked and know too check ok or new.
Simply put, truck ran in driveway, 5 hours later and ever since, just cranks and cranks....
new efi relay, new fuel pump, 44 psi KO jumped, AFM meter flap free and hear flapping when cranking, ohms checked on EVERYTHING..., new coil, plugs, wires, pulled timing cover- good belt, good timing (marks), alignment pins on both timing gear intact (didn't spin a cam), no codes, cold start injector not leaking, air tube ok-no wear or holes....
It is getting fuel and appears spark (plug pulled and verified) The ohms checked on the distributor plug. I am getting gas in my oil (changed twice already)
Pickup coil in the distributor? Ingintor weak? I could really use some help on this one!
Thanks in advance!
Charecter1
Nov 6, 2023 10:08 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Roger Borba II
Jul 9, 2015 05:05 PM
raiderhawks00
Jul 8, 2015 06:23 PM
