Where to connect that missing tach cable
Old Jul 25, 2006 | 04:23 PM
trythis's Avatar
Here is a picture of where I attached my tachometer cable under the hood on the coil cable cluster. Picture taken from behing the coil. Its the blue connector with the yellow wire coming from the terminal.
Old Aug 27, 2006 | 11:05 AM
mr3436's Avatar
Can you go into more detail on how to wire this up. I have the gauge cluster but Im pretty sure my truck isn t wired up for a tach.
Thanks
Old Aug 27, 2006 | 05:14 PM
trythis's Avatar
I ran a wire from the cluster to the wire shown above. The cluster has a place that you can find in the factory shop manual, that you have to add the wire. I don;t remeber how I knew where to plug it in or where to attach it.
[Coil]
lll <--wires
(0)(0)(0)
(x)(0)(0) <--- connector
l
[firewall]
l
[sr5 cluster]
the x marks the wire that you need to attach the tach wire to. I put a fuse in line, just in case.
Old Aug 27, 2006 | 07:36 PM
mr3436's Avatar
Thanks I figured it out. alot easier than I thought!!! Now I hope I adjusted my tach correctly..
Old Aug 28, 2006 | 06:38 PM
trythis's Avatar
Yeah, I thought mine was, but I am not taking that dash apart again. It isnt off enough to bug me.
jasonty
41
Dec 23, 2018 01:00 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
Esibnitsud
Jul 30, 2015 08:19 PM
altydog
Jul 28, 2015 10:20 AM
