- 94 Pickup Unknown Error Code
- Installed Herculiner Bedliner this Weekend
- Please Help With 87 4runr auto Hubs!!
- Throwout Bearing Question
- New on the site
- sticking gas pedal
- Rear differential drain bolt *&%&$*&(*%^
- CV axles just spinning, hubs locked or not!
- Ball Joint Spacers
- Yet another 3.0 bites the dust
- gear ratio?
- Could rich air/fuel mix cause CODE 52?
- whirring knock in my 22re
- omg, what a terrible intake system on 22re
- 3.0 problems
- add another 3.0 to the list
- Stock or Black Wheels.... with pics
- 3.0 v6 crank pulley bolt
- How important are gear Ratios???
- Setting TDC with valve cover off????
- load level bypass
- Newbie saying Hello: Some pics of my '93
- wanting to make my push bar into a brush gaurd
- rear seat belts for a 94 4 runner
- Screwed with the distributor...now I'm screwed
- Warn winch and brushguard assembly?
- 91 2wd toyota truck
- front ifs lift?
- 93 3VZE high idle
- How to set timing
- Power door locks won't stay locked
- 22RE Header and Exhaust
- 93 3.0 v6 needs a tune-up. Can anyone help?
- 15deg Adv, Code 26
- 1988 4Runner 3-VZE 2 questions....
- 4 runner auto tranny woes
- weird cooling problem
- Misinformation
- 3vze re assembly parts list
- Well, I broke my truck again....
- Por-15
- 90 4r 3slow exhaust question
- 22r-e air filter/intake
- 1990 skid plate bolts
- changing gears and lockers
- 1995 4runner idling rough
- 2 door 1990 4runner
- Which Exhaust?
- not feeling the love from the 94
- Why do you have a 2nd gen?
- CV shaft removal
- Loud squeek Please help
- Just bought 86 runner for $1200
- problems turning after front end rebuild
- rear vent, shade, wing, what is it?
- Two Catalytic converters inline, less polution?
- call me Shudders McGee!
- Power Stearing problems 91 4runner.
- Problem starting 22RE after rebuild...
- SR5 T100 Instrument Cluster Question
- Head Gasket Advice
- Stuck back window
- Who all makes BJ Spacers?
- help with a part number (3vze)
- Noise present all the time except when I give it gas.
- Where is the coolant temp SENSOR...
- will different brand gears work with each other??
- are these headlights worth it? partstrain.com
- third member and diff question
- floor jack
- 89 22r motor
- Lowering springs/coilover questions
- oil pan and engine block heater???
- Front wheel drive not working
- Burped cooling system for 42 minutes still gurglin! $%^&*
- Advise on possible 4 runner purchase
- looking at a 2nd gen. is it worth it?
- Anyone running a "basic" lift?
- alternator issues after river crossing
- Borla Muffler?
- 94 runner blowing smoke
- smokin
- suzuki hubs?
- Throttle cable
- off road driving
- One lucky SOB
- My newest mod.....
- Power Window Motor?
- Clutch problem and everything is new!
- Preferred 2nd gen repair manual?
- hub gaskets
- Height measurement
- My $1600.00 88 4Runner
- 2wd factory tire size
- 3vz to 3vz-fe swap
- dead v6 cylinders
- any tips for rear glass off the track?
- 275k miles, now what....
- Where to get clutch
- complete engine exchange $850
- rear brakes locking up when i wash the truck
- 340H upper valve body check balls
- planning transfer case rebuild
- 3.0 to 3.4 engine swap questions...
- trouble finding part numbers
- Clutch Slippage
- Just bought a '88 Yota 4Runner
- How to fix “CLACK CLACK CLACK” 22RE Block Rebuild
- First Mod... Awww :)
- My sr5 saddles need recovering...
- 95 Runner Auto tranny slippage??
- How to test a high output alternator
- Brakes applied=up and down idle
- Gear Oil Weight?
- Question about Power steering cooler
- Manual hub conversion kit
- Old Truck, New tires, goin stock--> AHH!
- what manual hubs fit
- Buzzing from dash
- Funny whining sound
- Rear spring from 79-85?
- Need Help in Seattle! (Starting concern)
- Truck stalls when I hit the gas
- OT: Honest people
- 94 Runner in snow
- isr mod...again
- brake problems
- Rear deck lamp switch? What does it do?
- More T-bar questions
- These Swaps should have no problem right?
- Front Axles??
- 300ZX brake lines for SAS?
- trouble finding specific bearing
- HELP! 3.4 swap problems
- Timing belt replacement..I screwed up..Help!!
- 33"X12.5"...91' Runner...No Lift?...Lotsa trimming
- Lift Advice::new Member
- 37's on a 2nd Gen 4runner - Pics and how much lift??
- Window compatability
- I would like to introduce you to my new 88
- Altimeter/inclonometer wiring question
- help....replacing fuel filter on 2nd gen
- turbo / supercharge install in a 2nd gen 3.0?
- Burned oil gunk on exhaust side of head..22re
- 22 re exhaust manifold
- Bad idle is proportional to bad performance
- random no start
- V6AT wont shift into OD
- diesel swap
- '91 4runner slight knock & high idle
- Lift REMOVAL??
- Diagnosis is in: What should I do?? 3.0
- Alternator/Battery charginf problems
- Engine swap
- Rear Add A Leaf
- Rear glass pickup interchange? What will fit?
- Need help with my flex-a-lite
- Traded My 86 4Runner for a 87 Truck
- 90-95 4Runner Transmission compatibility question
- 2Gen 4Runner rear (tailgate) window internal switch installed
- Anybody know of any bright headlight bulbs?
- something all over my rear brakes
- Need better gas millage
- compression test question
- Problems starting my 4runner
- Desert Rat store?
- tranny cooler question
- 92 Clock
- Rear disk conversion - anyone done it?
- Anyone want to offer some tips/suggestions for drivebelt changing?
- One more head gasket,lets fight
- What would cause exhaust manifolds to get orangish red hot on 1993 4 Runner?
- ARB OR TJM T17 front bumper choice?
- Problems with Hot engine
- what do you guys think of this truck
- Longer wheel studs!
- reverse lights ain't working!
- steering gear box
- Transmission Cooler
- Exhaust
- 1991 Pickup Front Brake Problem Question
- rescued from scrap yard
- fan wobbling
- New Yokohamas and AR's
- Switching a Cali to a 49 State
- Loud ratteling
- need timing advice
- Dead spot at ~2500rpm?
- A340 O/D Problem
- Front Bumper
- headgasket fixed a month ago and white steam again
- High beams (brights) won't stay on
- Transmission codes... All in one place
- Is this diagnosis correct? 3.0 V6 crankshaft bearings
- Quick question...lost battery bracket bolt
- Can I just replace fan bracket bearing?
- Best built long block on market
- 95 4 runner front winshild noise???
- 16" wheels 35" tires on 1st gen?
- manual hubs
- charge & brake light, on.
- Quick exhaust question
- My 4Runner brakes aren't very good
- Looking to pickup a 86-89 4Runner
- Advice for buying 2nd gen. 4Runner
- 3.0 Valve Adjustment
- 95 taco wont start
- Which Oil pressure sending unit?
- Repacking Front Wheel Bearings 4wd ?
- stereo install on 95 pickup
- Anybody got a pic of where the drain plug is for the block?
- ball joint spacer install
- Cold start problems
- Blown head gasket
- 95 4runner w/90 3.0 engine and 95 AT problems
- Planning to sell my old 3.0
- 1993 Toyota Oxygen Sensor Delete
- Losing power (esp. up hills) even after tune up
- 1988 headlight problems
- Steering column noise...
- Need opinion on 4Runner with engine problems
- pic request with bj spacers
- 22RE exhaust
- Timing Belt, cam/crank seals, oil pump, water pump. OEM or aftermarket better?
- is there a front leveling kit 2nd gen pickup...?
- Tacoma 5-speed and T-case
- snorkle???
- Pulling a 3.0
- How to Replace seal on steering gear
- alignment adjustment...?
- Replaced O ring on oil cooler
- A/T light, brake light, & battery light ON!!
- HeadGasket Recall eligibility- 94 22re
- Harmonic balancer
- oil pressure light, and knk sensor
- Smoking Exhaust at Low Idle- 22re 94 p/u 4x4
- Frozen Head bolt on a 22re
- changing a cv boot
- Adjusted TPS & now Code 41. Need help.
- water too deep
- Rough Idle.. Need Help!
- Help!!! Just did Timing job on 94Toyota 22RE
- Replacing plug wires
- Interior mat options
- truck wont start please help
- 3VZE turbo project teaser photos
- 33x12.5's on a stock 89 truck
- Cam Pulley Key Removal? (3VZE)
- Bought another 4Runner, Goodbye RustRunner
- cant pass smog 3.Slow
