Need help with my flex-a-lite
Old Mar 17, 2006 | 09:03 PM
sdstud212001's Avatar
Okay so I did a search first and nothing I found helped so here goes
Everything was going smooth until it came time to connect the A/C power switch, it's not that I don't understand how; it's I don't know where . Basiclly I need to know where to tap into the A/C. Can you share a picture and point out the specific wire. Oh yeah it's an 87 4Runner I bet that helps. Any help is better than no help, but not better than bad help so please only respond if you are positive it's the correct wire/way to do this. Sorry if that sounds harsh but I cant afford to ruin this fan is was kinds 'spensive to me.
Well thanks in advance
Old Mar 17, 2006 | 09:06 PM
Jeffires's Avatar
Find the wire that leads to the AC compressor. Start from the clutch on the compressor and trace it back toward the firewall. Tie into that- that's what I did to get my AC to turn on the fan. The wire on my '91 was blue I think.
I am positive that this works- mine's been like this for years. You may want to check the directions and see if they recommend fusing that wire- I didn't.
Old Mar 18, 2006 | 08:04 AM
thanks I'll give it a try.
Writeups@YotaTech
Jan 11, 2007 09:53 AM
Heebz
12
Jul 7, 2006 10:14 AM
TexJJ
May 30, 2006 08:37 AM
rimpainter.com
Customer Feedback For Vendors
Nov 6, 2003 01:00 AM
boss hog
9
Aug 18, 2003 02:20 PM
