95 taco wont start
Old Mar 14, 2006 | 06:38 AM
rabidmonkeyman's Avatar
95 taco wont start
Hey, im having a bit of trouble starting my car. When i turn the key all i hear is a spinning/whirling noise. its faint but i can still hear it. i think its the starter but i replaced that less then a year ago (about 5000 miles) and it hasnt been giving me any kind of troube prior to this morning when i tried to go to work. it wouldnt even try to turn over, as soon as i turned the key i just got that noise. i tried tapping the starter and that didnt do anything (worked on my old started when i had a flat spot on it) do you think it could be a worn flywheel? any help would be appreciated (im no expert at wiring or much but i know some general car knowledge)
Old Mar 14, 2006 | 09:00 AM
Bobakazi's Avatar
Sounds like you are not getting a good enough ground. Try removing your battery terminals and scrape them clean. Mix a little baking soda with some water and pour it on them. Rinse them off. Make sure they are good and tight when you put them back on.
Old Mar 14, 2006 | 09:02 AM
GodwinAustin's Avatar
check the contacts - throw some bulb grease on there.
Old Mar 14, 2006 | 12:28 PM
well i cleaned the battery posts with some special cleaner i had and that got away all the corosion and it started but somehow it didnt sound like it was the problem. when i turned it over it took really really long to turn over. ill check the spark plugs just to make sure, but i never thaught of the battery, thanks guys
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
