alignment adjustment...?
Old Mar 12, 2006 | 06:12 PM
chugs's Avatar
I have a 1994 toyota pickup v6 4wd. Just wanted to know if there is a good way to adjust/correct alignment without taking it to the shop?
Old Mar 13, 2006 | 08:05 AM
tc's Avatar
tc
search and ye shall receive instruction
You can do toe and camber pretty easy, but caster is pretty tough.
Did you just put on a lift or something?
Long story made short - get it close yourself, then take it to a shop. If you're going to 'wheel it, it would be worthwhile to look at a "lifetime" deal - pay once, and they redo it as long as you own the truck.
Old Mar 13, 2006 | 09:21 AM
midiwall's Avatar
This could help:
http://www.automedia.com/Align/It/Yo...cr20021201ay/1
TC's got the right idea though... Whack on it enough in your driveway to make it safe, then head to a shop and let them finish it up. There are mixed results here ont he forum about Firestone, but it's hard to beat their lifetime alignment deal. About $150 and you'll never pay for an alignment again.
fwiw, I'm in the "unsafe" boat right now. I replaced my upper a-arms with a set of ATS arms to get a bit more droop and didn't get it aligned. The net result is that my camber's trashed and the outside 2" of both front tires is now nearly bald. As well, the truck has a nasty tendency to "sail" when shifting lanes at highway speeds.
Gotta whack on mine.
Old Mar 13, 2006 | 03:54 PM
chugs's Avatar
thanks for the info, I was gonna put on some new tires and was just wondering if there is a do it yourself alignment adjustment..
Old Mar 13, 2006 | 06:15 PM
Quakefire's Avatar
I had a problem with the alignment on my 90, the adjusters froze so i cant do caster/camber
ladybugRC
458
Aug 21, 2020 10:41 AM
stanz
Oct 30, 2015 10:33 AM
voiddweller
Sep 28, 2015 11:21 PM
gyroscope7
Sep 21, 2015 04:55 AM
gyroscope7
Sep 13, 2015 05:15 AM
