truck wont start please help
Old Mar 11, 2006 | 05:27 PM
88yotaboy's Avatar
1986 toyota pickup 4x4 sr5, 5spd, 22-re unknown mileage.
The truck wont start. I have tried many things and at one point it was starting and running for about 5 secs then dieing, then i tried this fuel pump check thing ( http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump scroll down to the fuel pump tricks) and i think i screwed it up worse ( now that i looked at the site again i think i may have jumped the wrong connector and fried something, but i dont know what) because now it wont start at all, still turns over but wont start, and the fuel pump wont turn on. I know the pump is still good though because i hooked a wire to it from the battery so i could bypass everything and see if it was still good, and it is. I tried replacing the resistors in the fuse block and the resistor in the engine bay( passenger side one) and i replaced the in cab open relay above the ECU, all to no avail.... the check engine light still will not turn on when i turn the key to the on and start positions like it should, and the fuel pump is not turning on. Ive tried everything that i can think of.... please help me .
Thanks,
Andy
Old Mar 11, 2006 | 06:17 PM
nunsa's Avatar
Thanks,
Andy
Did you check the fuses besides the resistors? A fuse will go 1st check both panels, the one under the hood and the one on the kick panel!
You blew a fuse! I doubt it's your fuel pump!
Old Mar 11, 2006 | 06:46 PM
Blair's Avatar
Replace your EFI relay. If you hooked up in reverse-polarity, you have fried it. It sits in the fuse block on the passenger-side of the engine compartment.
Old Mar 11, 2006 | 08:02 PM
88yotaboy's Avatar
yep ive checked and rechecked all the fuses.
Old Mar 11, 2006 | 08:03 PM
88yotaboy's Avatar
is that the big burgundy colored one?
Old Mar 12, 2006 | 12:14 PM
Blair's Avatar
Not sure of the colour on a 1st gen, but it is a larger 'fuse' type of box. If you pop the top of it, you will see a diode across two contacts. This is the relay that sends the signal to the computer that sends the signal to the fuel pump. No relay = no fuel pump = no start.
PS: I learned this when I hooked my battery up in reverse polarity. Fried the 80 amp and the EFI relay. Replaced them, hit the re-sets on a couple of relays, and I was back in business.
Old Mar 12, 2006 | 01:33 PM
88yotaboy's Avatar
how do i reset the relays?
Old Mar 12, 2006 | 07:12 PM
88yotaboy's Avatar
bump!
Old Mar 13, 2006 | 08:33 AM
88yotaboy's Avatar
bump
Old Mar 13, 2006 | 02:54 PM
Blair's Avatar
Sorry about the bumps, I'm out of town and connecting via the hotel wifi...waaaayyy better than dial up at home....
There are several relays that I had to re-set. One of them is under the dash, just over the pedal bracket. Looks like a little silver pot, with a re-set button. THere is another one in the right side kick panel, not certain about these locations for the 4 cyl.
4X4Lamm put me on to them about two years ago. If he doesn't chime in here, just PM him. Good luck and let us know how it goes.
Old Mar 18, 2006 | 04:30 PM
88yotaboy's Avatar
i couldnt find a single reset button.. but i did figure out that there is no power getting to the ignition system... nothing at the coil/ignitor and nothing at the ign fuse on the fuse block..... im stumped...
Old Mar 18, 2006 | 06:45 PM
Saint_Berzerker's Avatar
This might sound like a retarded suggestion, but make sure you check all the fuses with a meter.
Sometimes they look perfectly fine but they're blown. I had one like that one time and I wasted like 2 hours until I found a blown fuse with the meter that looked good.
Old Mar 18, 2006 | 06:53 PM
Blair's Avatar
Did you replace the EFI relay and the 80 amp fuse?
Old Mar 18, 2006 | 07:19 PM
Blair's Avatar
Check your PM's...I have a diagram for you.
Old Mar 22, 2006 | 01:30 PM
88yotaboy's Avatar
ok well i got it to run... i figured out there was 2 problems... one was a fuse that was blown but looked good still, and the other problem was the ignition is faulty, so we put a hot wire to the started and got the truck to start. thanks for the help guys
Old Mar 22, 2006 | 03:24 PM
Blair's Avatar
Which fuse was it?....80 amp???
Glad to hear you're good to go.
bigblue82
10
Jul 6, 2015 08:27 AM
Badger62811
Jun 26, 2015 09:26 PM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
