Clutch Slippage
Old Mar 21, 2006 | 06:38 AM
dmatter's Avatar
Clutch Slippage
I am Narrowing Down the Oil Leaks on My Truck! I Found an Improperly Tightened Down Valve Cover on The Passenger Side. I am Convinced I have a Blown Rear Seal As I am getting a Little Bit of Oil Coming out of the Wheep Hole in the Bell Housing. My Question is....Can a Leaking Rear Main Seal Cause an Automatic Transmission to Slip a Little Bit. It only Slips When I Rip on it Pretty Good and the Transmissin Kicks Down the RPM's Go up But the Truck Does'nt Accelerate for a Second. The Slippage is Minimal Just Trying to Avoid More Problems Later.
Thanks Guys
Dax
Old Mar 21, 2006 | 06:48 AM
eric-the-red's Avatar
A leaking rear seal won't cause slipping on an auto, it must be an internal problem inside the transmission. Seal leaks only cause problems with clutches as the oil gets on the clutch. Auto trannies are sealed so there is no way for engine oil do anything.
If this is on your 4Runner, with 284,000 miles your tranny might be getting to the end of it's life.
Old Mar 21, 2006 | 07:29 AM
the_4runnin'_beast's Avatar
if he has lost enough trans fluid, it could cause a slight slip. the fluid pump becomes deprived of fluid for just a second, causing slippage. once it catches up to itself and starts to get atf back in circulation, it will catch and start to move.
Old Mar 21, 2006 | 12:24 PM
dmatter's Avatar
It Is Very Very Minimal Slippage an GM Driver Would'nt know the Difference I was Just Wondering if it Was Correctable. It is Tolerable.
Old Mar 21, 2006 | 12:45 PM
how much fluid you got in the tranny?
Old Mar 21, 2006 | 12:47 PM
dmatter's Avatar
I Checked it the Other Day While Hot and it was to the Hot Line on the Dip Stick..Maybe a Little Over it Was Still nice and Red and See Through.
Old Mar 21, 2006 | 12:48 PM
dmatter's Avatar
What is the Best Way to Check it???
Old Mar 21, 2006 | 02:42 PM
rpeAMP's Avatar
You don't want to overfill your transmission, so how much was it over?
Old Mar 21, 2006 | 02:46 PM
that is the best way to check it. but, like the guy above me said, you shouldnt overfill it.
Old Mar 21, 2006 | 04:24 PM
dmatter's Avatar
I will Take it for a Drive tonight and See how Overfilled it is.
Thanks For the Help guys
Old Mar 22, 2006 | 08:55 PM
dmatter's Avatar
It seems to have Plenty of Fluid it was Exactly on the Hot Line after a Good bit of Wheeling in the Woods. Clutch is Starting to slip More and More. I wonder what Fails and What it costs For a Freshen Up. Maybe I should Pull the Pan and Clean the Filtering Screen?? I have Heard of this.But,My Haynes Manual Does'nt Give any Detail."Imagine That"....
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
