help....replacing fuel filter on 2nd gen
Old Mar 19, 2006 | 09:21 AM
hill's Avatar
so this morning im trying to replace my fuel filter.. just curious how much gas is going to hit me in the face once i disconnect the lines on either side of the old filter.
I was planning on opening my gastank to take the pressure down a little...
anyone have any other suggestions/tips/hints for me ?
Thanks
Old Mar 19, 2006 | 09:23 AM
V_Runner's Avatar
Banned for stupidity
not that much...i did mine and ony what was in the line came out...just have a bucket...you know with prices these days you want to save every drop...
Old Mar 19, 2006 | 09:27 AM
Crymson's Avatar
Thanks
Pull the wiring harness from the fuel pump. Start your engine and let it die, crank your car over a couple of times afterward, and your lines should be relatively free of fuel.
Old Mar 19, 2006 | 09:28 AM
hill's Avatar
k... probably going to go get some flare nut wrenches first....
Old Mar 19, 2006 | 09:43 AM
V_Runner's Avatar
just don't do what i did which was break one of the lines...then you got to replace it...
Old Mar 19, 2006 | 10:05 AM
Elton's Avatar
there anit going to be much fuel coming out ...use some pb blaster it will help
Old Mar 19, 2006 | 10:20 AM
ChickenLover's Avatar
PB blaster for sure. Loosen the gas cap to depressurize. You won't lose very much gas (maybe half a quart). You might find it easier to unbolt the crossmember for more hand room.
Old Mar 19, 2006 | 12:31 PM
hill's Avatar
the cross member is connected to the transfercase or transmission.....
help.... i cant get access to the second nut with out removing the cross member,... but im worried the transfercase or transmission wont be supported... plus there are 3 hard to get at bolts to disconect the crossmember from it...
any pointers??
Old Mar 19, 2006 | 12:35 PM
Unbolt it from both sides. Let it droop down (it'll be fine). The crossmember will flex enough from side to side to get your hands in there. You'll need a jack to lift it back up to reconnect it.
Old Mar 19, 2006 | 12:52 PM
freshman's Avatar
i just went to canadian tire and they did it for $30 canucks and i am free of any worries. Its hard to do it for our toyota here in canada coz of the rust!
I tried doing it but i gave up because i will surely break something before i will be able to replace it.
btw, i bought the fuel filter from the dealership and they want to charge me $80.00 to install so i shopped around.
Old Mar 19, 2006 | 01:30 PM
hill's Avatar
thanks for the tips....but alas after droping the cross member and fighting with the last nut for 3/4 of an hour... i finally gave up and had to bolt back everything....
Old Mar 19, 2006 | 01:31 PM
hill's Avatar
im not super happy with the service at canadian tire...maybe ill ask the exhaust workshop to do it when i get a new cat...
Old Mar 19, 2006 | 03:22 PM
87rustbucket's Avatar
thanks for the tips....but alas after fighting with the last nut for 3/4 of an hour... i finally gave up and had to bolt back everything....
Boy i must be lucky-my bolts had rusted off years ago!!
Old Mar 20, 2006 | 07:53 AM
92runnersr5's Avatar
which way did you go at it .... if its the 22re im a big guy with big hands and managed to get everything off. i took off the tire and a little panel under the fender and with difficulty go them. if not the 22re then i dunno!
Old Mar 20, 2006 | 09:30 PM
RBA's Avatar
RBA
Arrow
Here you go, courtesy of 4x4wire.com
3.0 fuel filter replacement
Old Mar 21, 2006 | 04:34 AM
Etype R's Avatar
I did not remove my crossmember when I changed mine. Though I did end up snapping the front fuel line because the nut had rounded out.But the new line was only $35 at the dealership and was very easy to replace.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
pyramid
Jul 30, 2015 10:05 AM
Fundy Rider
Jul 16, 2015 01:35 AM
