Switching a Cali to a 49 State
Old Mar 15, 2006 | 05:02 PM
fierohink's Avatar
Question Switching a Cali to a 49 State
I've come to the conclusion that I have a california model truck. 2 o2 sensors, lots more emissions crap, vacuum lines galore. Anyway is it possible to swap back to being a 49 state vehicle? And if so, what needs changed?
Old Mar 15, 2006 | 05:06 PM
JamesD's Avatar
It would be more of a pain in the butt more than anything. I think the computers are different as well but I am not sure. It isnt worth the hassle. Dont you have the vacuum diagram sticker still under the hood? That would tell you if you have CA emissions or not.
James
Old Mar 15, 2006 | 05:08 PM
fierohink's Avatar
No the hood has been replaced and the owner didn't get a new sticker from the dealer. That's on my list of things to do.
Old Mar 15, 2006 | 05:30 PM
JamesD's Avatar
The dealer can run the vin for you and tell you if it is a CA model or not.
James
Old Mar 15, 2006 | 07:05 PM
trythis's Avatar
I wish I had the california emissions. Last thing I want to do is dump more poison into the air.
Old Mar 15, 2006 | 07:24 PM
RustBucket's Avatar
last thing i want to do is downgrade my 116hp truck to like, 90hp
Old Mar 15, 2006 | 07:40 PM
Keggo's Avatar
I'm with you trythis... I'm more than happy to have a CA vehicle.
Old Mar 15, 2006 | 10:13 PM
kyle_22r's Avatar
what you're hearing is a bunch of baloney. with EFI, there really isn't a big difference in anything. now, carbs are a different story(compare a canadian emission with a cali emissions in '83!), but this is far more modern technology in your engine, and there aren't that many vacuum lines, even on a CA engine.
then again, many people were so used to(or taught by those who were) that EVERY emissions accessory robs huge amounts of power so they're willing to screw everything up in the process of dumping every little component they don't think they need.
Old Mar 16, 2006 | 06:19 AM
trythis's Avatar
I think the only thing your CA engine has that we dont have is an extra O2 sensor and a charcoal canister on the fuel line. The rest of the 22re's out there also have quite a few vacuum lines and little do dads that they hook up to. The FSM doesnt show that many differences in 49 and CA's
Old Mar 16, 2006 | 06:43 AM
fierohink's Avatar
Well the charcoal can is definately a problem. Whne it gets hot out, it doesn't process vapors quick enough causing overpressurization of the fuels lines and having raw fuel pushed out of the couplings. If I unseat the gas cap and let alll the vapor release the fuel leaking stops, so I know it has to do with over pressure.
I have on my to-do list pulling the can and trying to blow air through as prescribed in the FSM. Yipee
Old Mar 16, 2006 | 09:33 AM
midiwall's Avatar
You might wanna read this and follow Fink's issues through trying to get rid of one of the cats:
https://www.yotatech.com/forums/f2/dual-cat-converter-4runners-67521/
We're still kinda' waiting to see how it turned out...
Big Little Bear
230
Nov 13, 2023 11:42 AM
Daenerysdad
Oct 1, 2015 07:33 PM
JamesDINAN
Sep 22, 2015 05:37 AM
runnermedic
13
Sep 21, 2015 05:20 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
