Loud ratteling
Old Mar 15, 2006 | 04:49 PM
Frost's Avatar
Loud ratteling
Hi, i was wondering if any1 had this problem or at least knows what it could be. The problem is i have a loud ratteling as the titel sugjests, but i cant seem to get rid of it, i know its not my bearings, idler arm or my tie rods. Any other sugjestions?
My truck is a 1987 toyota pickup 2.4rec IFS
Old Mar 15, 2006 | 05:29 PM
Flash319's Avatar
Catalytic converter heat guard unter the driver floor? You discription is not very clear. What area is the noise comming from? The engine? Does it change if you rev it up? Only when you are moving????
Old Mar 15, 2006 | 05:36 PM
Frost's Avatar
sry bout that. ummm.. lets c well theres no cat. not 1 worth mentioning, i busted out all the stuff on the inside. as far as i can tell the most off the noise is coming from the front of the vehicle. and it is mainly at 40 and 55-60+ so reving it doesnt matter and yes only when im moving.
Old Mar 15, 2006 | 05:51 PM
Elton's Avatar
you better get it fixed mine stater doing it wich i thought it was a vavle guide well it turned out to be the timeing chain wich broke cusaing it to lock the motor up and took the head along with it now i have to get a new head ... timing chain .... and a headgasket
Old Mar 15, 2006 | 06:09 PM
Frost's Avatar
lol. im trying to get it fixed but i dont know what it is :/ lest not yet thats y im here
Old Mar 15, 2006 | 07:11 PM
Elton's Avatar
i would look at the vavles first and see if any thing is lose or broke
Old Mar 17, 2006 | 02:14 PM
FingerMan20's Avatar
can you hear it when you first start the truck? and is it 40-55 mph under accelleration that it makes the noise? does it sound like a bag of marbles, kinda? because if it does (you will know), that is the sound of your timing chain rattling against the timing cover on the forward part of the engine.
does it make that sound though? if it does, there are a few things you could do to splint the wound, or a couple things you could do to cure the disease entirely.
Old Mar 17, 2006 | 04:43 PM
Saint_Berzerker's Avatar
Does the vehicle vibrate or do you just hear it?
I had a similar sound/vibration when my ujoints were going out, then my dang driveshaft fell off...lol
It was only at around 50mph too.
Old Mar 18, 2006 | 10:39 PM
Frost's Avatar
Its mainly under accerleration but its pretty consistant. And its only at speeds, not an rpm thing. and yes saint it has a vibration. if it is a driveshaft.... im glad i have a 4x4
Old Mar 19, 2006 | 05:29 AM
brendonv's Avatar
Both of my trucks have always done it. 87 22r and my 93 22re. The 22re has new timing chain components but i just think its something with the exhaust. I'll fix it when it blows~
Old Mar 22, 2006 | 04:41 PM
Frost's Avatar
yea just looked close at my u joints and um yea theres alot... alot of play. its amazing how easy it is to see when you have no bed
JNapolitano
Nov 14, 2019 07:46 PM
Corvoid
Dec 11, 2015 11:21 AM
Davebarbier
Nov 3, 2015 03:28 PM
JPV
Sep 28, 2015 03:15 PM
93RedKrawler
Sep 25, 2015 04:03 AM
