pic request with bj spacers
Old Mar 13, 2006 | 06:12 AM
wiebs6's Avatar
Can you post some pics of 89-94 pickups with bj spacers and tell me what you did for the rear lift
Old Mar 13, 2006 | 06:37 AM
Buck01's Avatar
I dont have pictures for you cause I dont have the BJ spacer on yet. I did however get the extended shackels on for the rear.
Old Mar 13, 2006 | 09:27 AM
mtrdrms's Avatar
Pictures of the shakles?
Old Mar 13, 2006 | 06:05 PM
BeaterToyota's Avatar
I know this isn't the year you requested, but here is my '88 with bj spacers up front and a 1.5" lift shackle in the rear.
Top picture is with 32x10.50 tires (sorry I don't have any pics of it parked to get a good look at it).
The bottom picture is with 36x12.50 tires (they don't really fit, but my junk is getting SAS'd whenever I get around to it so I just stuck 'em on to see what it looks like).
Old Mar 14, 2006 | 07:42 AM
F0RSAKEN's Avatar
Looks nice (aka fun ). Any downsides to the spacers?
Old Mar 14, 2006 | 02:04 PM
The ball joints will wear out faster. I put new ones in a couple of years ago when I installed the spacers, and now both upper ones are shot. But I've also wheeled the crap outta my truck. A daily driver or a rig tht doesn't get wheeled much will be fine.
Old Mar 14, 2006 | 03:32 PM
gonzo's Avatar
ok I got a ? on them too. how hard is it to align the truck after? I been thinking about them but been putting it off. Also how much did it actually lift the front?
Ty
Gonzo
Old Mar 14, 2006 | 05:46 PM
Since my rig is just trail junk, I never got my alignment done. I still drive my rig to the trails though, and the tires are much more worn from trail abuse than they are from the (slightly) mis-aligned front end.
I don't remember how much lift I got 'cause it's been a couple years, but it was somewhere between 1.5" and 2".
Old Mar 14, 2006 | 08:12 PM
BLKNBLU's Avatar
Mine aligned OK although the guy at the shop said he maxed out the adjustment cams to get it within spec. Lift is kind of up to you. After I installed mine, I lowered the t bar adjustment til it was actually a bit LOWER than originally. My intent though was to gain articulation not lift. If/when I go to bigger tires I will have to make some adjustment.
Old Mar 14, 2006 | 08:27 PM
BLKNBLU's Avatar
Also here are some pics. I know it's not the right year or a truck but it is the same suspension.
In action:
Sorry this is the best I've got of it just on level ground, but I think you can get the idea.
Old Mar 14, 2006 | 09:48 PM
Asha'man's Avatar
BLKNBLU, those pics are with the 31's? Looks pretty sweet.
Brian
Old Mar 15, 2006 | 07:32 AM
BLKNBLU's Avatar
Brian
Yes, with 31's. Everything in the signature is still correct. Thanks.
Mike
Old Mar 16, 2006 | 11:11 PM
myredyota's Avatar
Here is mine on 33's:
And on 31's:
For the rear, I added a few extra leaf springs.
Old Mar 17, 2006 | 06:10 AM
wiebs6's Avatar
hey myredyota how much pounding and cutting did you have to do so thoughs tires don't rub
Old Mar 17, 2006 | 09:47 AM
myredyota's Avatar
None! Those are my friend's tires that we were just trying on. They are SSR's and actually measured 33.5". We flexed it pretty well and still did fine. I will probably just go with 33x10.5 once my 31's wear out.
Old Mar 17, 2006 | 08:16 PM
wiebs6's Avatar
what was the backspacing and tread width on though SSR's
Old Mar 17, 2006 | 08:19 PM
myredyota's Avatar
3.75" and 12.5"
Old Mar 18, 2006 | 08:23 AM
wiebs6's Avatar
myredyota what are your fender to rim measurements
Old Mar 18, 2006 | 10:47 AM
myredyota's Avatar
16.5" front and only 14" in the rear with a topper on it. I do plan on doing a rear u-bolt flip. When I do that, I will be adding another leaf to level it out some more.
Obmi
Sep 16, 2015 02:13 PM
Regency
Sep 6, 2015 05:47 PM
Badfish740
Sep 4, 2015 04:21 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
128keaton
Sep 3, 2015 05:09 PM
