modules underneath drivers kick
Old Feb 14, 2006 | 11:26 AM
daniel_loz's Avatar
I need to know what the two modules that are located directly behind the drivers side kick panel are called...there are two black boxes, one large and one small...and then the fuse block is there as well...all this got wet and im thinking im going to have to replace the two black boxes i just dont know what they are called...thanks for the help
Old Feb 14, 2006 | 02:48 PM
eric-the-red's Avatar
The manual shows the relay and ecu for the cruise control there.
Old Feb 14, 2006 | 03:00 PM
aviator's Avatar
I seem to recall that at least one of the boxes is for the power windows/doors. At least thats the case with mine after i added the stuff. aviator
Old Mar 18, 2006 | 11:32 AM
Toyo-Mama's Avatar
did you rule out the soure of the water? I have a constant leak that I think comes in through who knows where and runs down along that fuse block...
Your cruise control is there, and your door locks, I believe. Your power window relay is behind the driver's seat, by the seat belt, under that panel.
Good luck if you replace that block. You can buy some time with some aerosol parts cleaner. I'd like to hear where you found one, if and when you do.
RobotMoose
Sep 2, 2015 05:53 AM
viesail
Aug 24, 2015 12:21 AM
91yotapup
Aug 17, 2015 09:40 AM
Koolbananass
Aug 12, 2015 01:59 AM
coryc85
Jul 6, 2015 04:07 AM
