- 3.0 cooling issue
- 4Runner bumpers
- Ever overhaul your own 87 5 speed transmission?
- Head gasket time...
- 86 Wire Harness Rebuild Help
- [1991 4Runner] Bottom of the radiator leaks when pressurized
- 87 4X4 truck fuel sending unit compatibility, plus update on my truck
- sensors discontinued for 22re s
- 22RE Idle Surging, RPMs drop before trying to recover
- Wiring Harness Routing
- Fuel leak from charcoal canister
- 3.0 injector question.
- hydrolock
- Can 2 people liftup the bed of P/U?
- Charge Light Relay Conspiracy
- '91 22re cel code 27
- need help identifying wiring plugs '91 22re
- 22RE rods and caps mixed up - engine binding
- 1 Inch bore master cylinder comparison
- 4runner 3.0 power issue not the usual
- Brake Lights
- Vacuum hoses HELP
- 3.0 stutter got some bad vibrations
- I got a question about the coolant temp sensor
- egr, cat, Injectors??? super high NO PPM reading
- o2 Sensor Simulator??
- 4 cyl calipers for rear disc setup?
- Exhaust Stud length
- 87 4runner hub cover removal help
- after market filter on stock carb
- Does the gear ratio matter even if the front shaft is unhooked?
- 22re afm and air box out if a 2.0 camry?
- Faulty TPS IDL - e2 FIX!
- what oil pressure switch need?
- Swing away tire carrier
- Aftermarket body parts any good ?
- 3vze- Bad gas mileage, Bad idle when put in drive
- 87 Interior Handles Dr and Pass the same?
- Oem rubber bushings or poly bushings
- Seat ?
- Obd1 17 pin to obd2 16 pin adapter question
- One Pcs Drive Shaft question
- Shackels
- o2 oem vs ntk
- Twin leaks
- Gangsta lean help
- Oil pressure gauge issues Factory gauge
- Air Injection Tubes?
- Marlin shifter seat & socket replacement
- 1st Gen 4Runner Cup Holder
- Extension house seal
- 89 front end vibration
- 95 3.0 4Runner Cranks, no start
- Gasket kit info
- Burning rubber smell from exhaust hangers
- New Distributor, plugs won't fit
- Need help with 1994 3VZE Pickup
- Replaced Fuel Filter Now Hard Warm Start
- i swap my Tach but not work well
- I want inclinometer cover
- need help finding some pigtails
- Transmission oil cooler system
- Throw code 25 and whirling noise in 3rd and 5th
- bushing kit
- Replacing Motor...aftermarket advice?
- 1993 PU clutch slave bleed screw size?
- Exhaust Mainfold Sensor port
- pre + post o2 same?
- Bushing question
- Chance to buy 85 axle
- 1990 clutch pedal no pressure and strait to floor
- My first 4runner
- 0.030 shims needed with IFS diff bearing replacement?
- 22RE stumbling worst now...
- Need to haul more weight. What route should I go?
- 94 toyota 22re running problems!!!
- will 31's rub with ball joint lift up front?
- 86 pickup auto transmission problem
- Another 3.0 needs help guys!!!!
- No instrument lights.
- Head gasket Failure Help!!
- Link to detailed parts diagrams??
- Need help. Speedo
- Very rough idle when warm 3.0L 4runner
- 89 lift suggestions
- New To Yota Tech 87 4 runner sr5
- need part # please
- 1988 Pickup Differential Fill Plug Swap - Low Profile 10mm Hex Drive Magnetic Plug
- Why reverse?
- I removed the carpet and....
- 94 3vze overfueling hard to start
- 22RE Ticking....
- lift
- Toyota knock sensor saga
- Bad miss
- 1992 pickup water jetting from timing cover gasket
- Lets see your tranny swap pics. w56
- What is this stuff??
- SPartan/ATK engine 22RE
- Transmission question
- Nissan lug nuts on a Toyota?
- TURBO SR5 sticker on tailgate
- speedometer on 87
- 1st Gen 4Runner rear bumber end caps / stays
- torsion bar is rubbing on driver side cab
- 22re megasquirt vs webber vs mafm
- Camshaft caps in wrong order...too late?
- 3vze trouble again no idea why
- Need 86 FSM
- 3VZE with low vac, rough idle, and strange noise
- adjusting wheel lock tabs
- CamShaft Help
- new here with questions
- Engine Reving
- 93 4WD Vibration
- Automatic Tranny not shifting properly 91 SR5
- Trying to diagnose engine noise...22re
- 94 22R Leaf mod help
- Idle problems
- Can I interchange slave cylinders Aisin CRT001 (31470-30260) & CRT017 (31410-35250)
- Push brake, dash lights come on
- 3vze head gasket torque specs
- Steering/Suspension - new ball joints / TREs
- cam timing
- Removable Vacuum Systems
- Ruff ride
- Need advise might be buying this 87 4runner SAS
- radiator fitment
- 93 4runner 4wd 6cylinder
- New to here and just got a 1988 toyota truck
- Colorado bound
- Need some Help Please with transfer case
- MAF Troubles?
- (22re) Is starter locking/sticking & binding keeping engine locked common?
- rear wiper delay
- panhard drop
- Starter replacement
- 22RE Running Poorly - Vacuum and Spark Plug Issues
- Finally found the problem..
- Oil out of the muffler!
- Slippin!
- 22re heat issue
- Bought new 94 Pickup: Need Beginners's Help!
- New trd wheels
- 3vze totally stumped, no old posts helped yet.
- 94 4runner V6 3VZ. Terrible noise when turning hard.
- Needing suggestions for a lift.
- Clutch Fork Boot
- need help with front diff
- Fair price for differential?
- Automatic Shifter Problem
- 94 3.0 false water pump problem
- '87 4Runner Ice Blocking Heater Fan
- rear driveline problems
- Engine Heater
- 4runner belt squealing crank pulley busted ???
- Factory LSD???
- Limping a blown head gasket home
- tire size
- I need help sourcing rubber bumper for tailgate striker
- Specific regear question 1st gen 4runner
- Removable Top Bolt Cover Trim
- Fan Constantly Running
- 3.0 having symptoms of a dead cylinder.
- Head gasket recall
- fuel pump
- Manual Mirror housing tighten? 93 pup
- Body swap possible?
- I got stuck in the ditch.
- Mystery issue
- '92 Toyota dlx - warble noise & wheel hop
- 93 Pickup backfiring very hard upon start.
- Curing oil leaks and valve noise with the right oil
- 95 3VZE Emissions Failure
- Birfield clip question
- Ignition Lock Cylinder Replacement Problem
- Need Help...Mechanic says Oil Pump
- 90 pickup direction ideas?
- Questions about Stale Gas
- 92 P/U 22RE 5-Speed Cranks over strangely
- Random Dead Battery
- 3.4 Flywheel bolts
- need help newbie
- fuel damper problems
- Parts needed for installing injectors?
- 1990 Hilux: Need the bolt for my hub
- Injector test and cleaning?
- 1990 toyota dlx 3.0 5 speed steering box leak....Repair???
- Door handles....
- Advice on a new motor for 90 4runner
- Compression test and head gasktet quetion..
- Rear window
- Help! 1991 toyota 4x4 pick up 4wd not working.
- ADD question again
- Any suggestions while engine is out?
- Setting torsion bar preload?
- Best way to check timing chain on later 22RE?
- No bright headlights
- 88 22re throttle sticking when cold and idle rough when hot
- Running a lot of ignition timing? Stock 22R w/ stock carb
- 1990 4runner
- Does '91 3vze use a starter relay?
- Looking for 1 ton swaybar and torsen bars
- unholy sound from engine
- 1988 pickup overheating and spastic idle
- DIY Header?
- 22R Carb
- 89 3.0 4X4 auto trans, no drive. Help!
- Newbie with 4x4 problems
- 4Runner Removable Top
- How much brake fluid required to completely flush brake AND CLUTCH? 91 2wd
- 2nd gen 4Runner trans question.
- 87 toyota rear sag
- Excessivly High Idle
- 94 p/u ls swap and sas
- 92 toyota pickup trouble starting
- 1986 - 88 Same hood? 4x4 and 4x2??
- No start, spark but fuel? fuel injection issue?
- 88 pickup, 32x12.5R15 on stock height??
- having a hard time picking
- smelling raw fuel and exhaust
- 87 4runner windshield
- help
- Towing a 91 4x4 4Runner
- Missing egr temp sensor?
- Alternator works well, intermittently
- 89' pickup heater not working
- Leaf spring center bolt - where's the head?
- troubleshooting very poor mileage
- Cranking 22RE wont start with end result posted!
- Newbie Needing Help Posting in Classifieds
- New member, goofed on pilot bearing
- HILUX Corner lights
- Ideas on lifting my truck
- Hi Guys!
- 86 pick-up rebuild
- Are 3vze and 3vzn parts interchangeable
- broke the timing chain....why?
- 16 instead of 15 rims and tires on 1st gen How much power loss
- Pickup door pannels
- Cam Bearings?
- fuel leaking from the intake plenum
- Looking for the MOST Comfortable seats to swap in
- help. truck stumbling grr
- 3 alternators in less than a year!
- Buying an 89-95 what to watch for?
- Truck will not start, just click/buzz on passenger side.
- First post, help much appreciated!
- Front in grinding need help
- Clutch problem
