ADD question again
Old Jan 3, 2015 | 10:20 PM
9four4runner's Avatar
ADD question again
So a while back, I'm talkin years, I read somewhere that you can take off the shift fork on the add and slide the sleeve over and engage it into the 4wd and wrap a hose clamp or two and install manual hubs and run this set up
Is this possible? And if u know the tread where's it at?
Old Jan 4, 2015 | 01:25 AM
wyoming9's Avatar
Red face
Yes But why would you if the ADD still works.
I have the best of both locking hubs with ADD
Since the hubs stay locked in most of the winter .
Using the Search Engine of your Choice Search Toyota ADD delete should get you plenty to read.
Old Jan 4, 2015 | 07:33 AM
I'm doin the reed valve and egr delete so I figure I'd bypass the other vacuum lines also
And every time I search ADD Bypass it only comes up with the valve bypass with a electrical valve from Tacoma. I would just like to get rid of it completly
Old Jan 4, 2015 | 10:18 AM
wyoming9's Avatar
Red face
Not bypass ADD delete!!
simple to pull it apart figure how it works
secure the sliding part so it is engaged all the time with what ever means works best for you.
Old Jan 8, 2015 | 08:30 PM
Alright Ima delete it
edoyle12
11
Mar 20, 2017 02:26 AM
Ironmike4x4
Feb 3, 2016 11:13 AM
Bawlzdeep
Aug 2, 2015 08:35 PM
makemusic116
Aug 2, 2015 05:23 PM
defrag4
Jul 31, 2015 10:50 AM
