3.0 cooling issue
Old Jan 27, 2015 | 06:48 AM
jdmande's Avatar
3.0 cooling issue
Hi everyone. So I just did the water pump timing belt and thermostat on my truck and I noticed something this morning after driving it my lower hose and the lower part of my radiator are not geting hot just Luke warm to the Touch. Truck runs fine does not get hot i've burped it Gage stays about quarter mark but after I shut it off it goes to about the halfway mark. Is this something I should be worried about
Old Jan 27, 2015 | 07:06 AM
Marc's Avatar
I believe the flow goes from the bottom of the rad to the block through the thermostat so it would take quite a while for that hose to get warm.
Is the top hose and aluminum fitting on the block getting hot?
That's what I usually check with an IR temp gun.
Old Jan 27, 2015 | 07:33 AM
jdmande's Avatar
Yes the upper hose is geting hot and the water inlet to.but not so hot that I cant Touch it
Old Jan 27, 2015 | 07:52 AM
bswarm's Avatar
Did you turn the heater to full hot when burping the air? Does your heater get hot? The temp rising when you shut the engine off is the residual heat rising because the water pump is no longer running. If it's more than before then the coolant/water mix isn't correct OR you have a hot spot in the engine that isn't getting sufficient coolant flow OR you have a head gasket leak.
Old Jan 27, 2015 | 08:00 AM
jdmande's Avatar
Yes the heater was on and had the truck at a incline. There is good heat coming from vents
Alex Bessinger
Aug 31, 2015 09:17 AM
jackiebrownia
Jul 20, 2015 09:02 AM
tobylab
Jul 12, 2015 12:53 PM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
