Front in grinding need help
Old Dec 29, 2014 | 05:22 AM
curry's Avatar
Can anybody help me I have a 1988 toyota pickup 2.4 efi 4wd it has a grinding noise in the front it will grind when I lock my hubs in and still in two high and when in 4 high or 4 low it will not grind when hubs unlocked
Old Dec 29, 2014 | 07:21 AM
MudHippy's Avatar
Check your spindle bushings. They probably need greased, or replaced. You might want to inspect your front driveshaft u-joints too.
Old Dec 29, 2014 | 05:31 PM
curry's Avatar
The noise is comeing from driver side and it isn't always grinding only every now and then
Old Dec 30, 2014 | 05:11 AM
MudHippy's Avatar
Sounds familiar. Like I said. Spindle bushings...
Old Dec 30, 2014 | 06:30 AM
mountainbrew's Avatar
I may have a similar issue right now. 86 4Runner 22re 5spd. I was searching everywhere, but the problem(as stupid as it sounds), I can't figure out how to describe the noise!! This happens to me as well when the hubs are locked, regardless of whether or not it's in 4wd. The noise sounds like a cross between the t-Rex from JP, and gym shoes squeaking on linoleum. For sure not the classic clicking CV axle: However that sound only happens occasionally, and there is a whirring sound that happens all the time (hubs locked) and almost sounds like road noise from the tires. My searching has led me to believe it's the spindles, especially since it started happening to me during the first snow/ cold snap. Let us know what you find!
jashoeuh
Nov 18, 2024 08:08 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
kvanzandt1
Jul 18, 2015 10:15 AM
mengquis
Jul 13, 2015 10:39 AM
