need help identifying wiring plugs '91 22re
Old Jan 25, 2015 | 04:35 PM
yodapwnedjoo's Avatar
Just finished doing a head-gasket on my truck and am having trouble finding where a few of the plugs connect too
truck is '91 22re w56
although im finding some of my parts i have to get from a later truck, such as my coil/plug wires have to be from a '93 style with the smaller clip on style wires. So im not sure if the previous owner swapped motors or transmissions everything seems factory..
The plugs on wiring harness i cannot find.
#1 near the back of intake manifold i have this one with one blue wire and one brown. im not seeing where it would connect to .
#2 near the transmission . It is pretty long and and i see no where for it to connect either.
My backup lights are not working but i think i have those connected right, im thinking the wire is broken right at the connector for that where it looks kinked.
Old Jan 26, 2015 | 05:17 PM
slacker's Avatar
first plug looks like the A/C idle up plug ...
second wire looks like the speed sensor plug .. should plug in on the end of the transfer, passenger side .
Old Jan 27, 2015 | 02:34 PM
thanks, It looks like you are right.
I have no ac so the plug is just extra .
My speed sensor in the transfer case had been swapped over to the mechanical cable type to be compatible with my dash speedometer .
I noticed the plugs seemed dirty inside the connector so I thought mabey they were never connected but wanted to be sure
Thanks again
MO transplant
Apr 23, 2023 11:58 AM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
msane99
Jul 17, 2015 10:13 AM
bryan34w
Jul 6, 2015 05:53 PM
