PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 3.0 3VZE Cheap Headers
  2. Looks like some type of air control valve.
  3. Temperature gauge reading low
  4. Transfer Case leaking seal
  5. Rear wiper refill?
  6. Vsv
  7. ruined powerstering pump or wrong oil
  8. 1st gen 22re manual engine swap to 2nd gen 22re auto
  9. New Steering Knuckle for my 93 4x4 AISIN Hubs
  10. Tug between 50-60 mph that I can accelerate or decelerate out of
  11. 86 4x4 Washer Fluid Reservoir
  12. Torque converter for 94 t4r?!?
  13. Custom Bumper + Crane Build
  14. Stock Rear Shackles
  15. 1991 Toyota Pickup - 12 V Ignition "Switched" Power to Radio Dead
  16. K series Rekeying kit on eBaay
  17. Stainless braided clutch line?
  18. Starter solenoid wire
  19. Torsion bar trouble
  20. Fuel pump flare nut stuck. New bracket?
  21. What is this component?!!? (1995 T4R 4x4 V6)
  22. Aftermarket tach install 93 pickup
  23. 88 pickup 4x4 5 speed tranny help
  24. 3vze HHO
  25. Switches For This
  26. Power windows
  27. 4runner '89 3.0 V6- Rear Suspension refresh
  28. Need advice on '94 pickup front brake job
  29. Here's how to super-easily remove old 22re PCV grommets.
  30. Brake system upgrade
  31. No fuel at start
  32. 4Runner a mistake for the sand?
  33. Need some guidance with a 95 3.0
  34. 1991 3.0 timing
  35. Coolant rising Head Gasket Leak???
  36. AM1 fuse blows immediately
  37. Do ECU Swap 1995 3VZE need reprogramming?
  38. Driving straight/Allignment issues since the beginning of time
  39. Bushing for Front Differential Cover
  40. Diagnostic code interpretation problem 87 22RE
  41. ISO Seatbelts and buckles from a 86’ xtra cab truck
  42. AFM Short?
  43. Thoughts after pulling heads, 3vze
  44. 3VZE Fuel filter bracket neccessary?
  45. HEEEELLLLP (with evap coil ID)
  46. Other Work to do when replacing 3VZE knock sensor
  47. Fuel Pump Swap on '86 22R
  48. Starter issue
  49. Fuel seepage on fuel pipes No 2 & 3
  50. Does anyone know the make of this light bar?
  51. engine builders please chime in, looking for deck finish spec
  52. No brake lights
  53. 22r low compression !!
  54. Parting Out ‘84 Pickup, What to Keep?
  55. How to determine which cluster will fit
  56. Drive shaft
  57. 87 fuel pump wiring
  58. 2nd Gen 4 Runner stuck in park
  59. Just bought a 94 pickup 4 banger
  60. Aftermarket fuel caps For 22re Buyer beware!!!!
  61. What should I ask for my 4 runner?
  62. Need new vacuum advance, can’t find
  63. Odometer reset / trip meter replacement
  64. 1993 SR5 xtra cab 4WD vibration
  65. Brahma Shell Fasteners
  66. Corner marker light housing.
  67. 22R Air Injection Rebuild Help
  68. Timing advance, 3vze
  69. Detroit truetrac in 7.5" and A.D.D.?
  70. 93 4Runner Rear Brake Proportioning Valve
  71. Locking Hub Issue
  72. 87 steering box nightmares.
  73. Bud Built Skid plate and cross member
  74. Name this bolt!
  75. 22re Stumbling and falling
  76. Replacing W56
  77. Grinding noise, maybe valve related, above mid RPMs, 22r
  78. Entrance into engine bay from cab?
  79. AC idle up valve no power at connector
  80. front differential confusion
  81. 1992 Toyota 3VZ-E Pickup Chassis - Code 12 and 14, engine stalls and rough when idle
  82. 93 ECM part number question
  83. 1990 Toyota Pickup with 4 Runner Front?
  84. Ticking under load
  85. What bushing is this ?
  86. Knock sensor torque spec? 3vze
  87. 1st Gen 4Runner Rear Seats
  88. Car bogs at mid/high rpm and sounds like exhaust leak. But it isn’t?
  89. Sticking clutch
  90. Over Torqued the Idler Arm
  91. short circuit work around
  92. 180 Thermostat thermostat question?
  93. Any Extra Advice on Getting an '88 back and Running
  94. Found these under my new trucks driver seat, thought you all would enjoy.
  95. 95 Forerunner dilemma
  96. Fuel sending unit issues.
  97. 3VzE VAFM connector wired backwards??!!
  98. Considering restoration
  99. Help identify wiring connectors inside cab
  100. How likely is it I could change the spark plugs and wires on a 3vz-e being a noob
  101. 2nd gen t4r rear window upper trim removal
  102. Speedo to Trans. Issue
  103. 88 2wd lift
  104. Transmission lines
  105. 4Runner AC Condenser alternate source
  106. 94 Toyota Pickup 22re Problem
  107. Can Someone help me with Part Numbers?
  108. Dorman 621-177 Condenser Fan
  109. Blow-by Was Ruining My Air Cleaner Element
  110. Are 1-ton brakes really necessary for safety?
  111. What is this leak
  112. 3vz PS pump - goner?!
  113. **HELP** Fuel injector connectors
  114. Part # or Source for glass weatherstrip?
  115. 94 22RE fuel pump voltage loss
  116. a/c & airpump/smog pump belt problem
  117. 91 Pickup 22re Running Rough Idles perfect
  118. Question about AC in a 1989 1st gen 4runner.
  119. '88 3VZE No Spark Issue
  120. Stripped Cam Journal
  121. Killer Toy Tops and Roof Racks?
  122. Key Panels
  123. 32's?
  124. 3.0 strikes again
  125. pickup bed sides
  126. ... and here is where the stolen Toyota trucks are
  127. Chem-dip for piston heads in block 91 3vze
  128. Toyota motorhomes
  129. under carriage/driveshaft pics please
  130. Finding Replacement Door Trim...
  131. '93 4Runner Converted AC pressures?
  132. 4YR Head gasket job
  133. 22r intake coolant leak
  134. Help, broke the easy-out!
  135. Driveshaft Carrier Bearing - What Brand?
  136. Do you know this truck?
  137. 88 Toyota AC problem
  138. Feeler gauge 'feel' for valve adjustment
  139. 22re temp overshoot ONCE AND FOR ALL
  140. 22RE Slowly Overheating
  141. Front end grinding noise after any road bump?
  142. 1990 toyota sr5 v6
  143. windshield wiper fuid
  144. New clutch, new flywheel
  145. Drive Shaft
  146. Options for protecting fiberglass top?
  147. Check engine light on cold start
  148. valve clearance 3v and 5V
  149. Cel 52 & manifold removal
  150. Up and Going
  151. 22r carb hoses that I don’t know where to route
  152. 1993 Toyota 4x4 22RE VAFM Code 31
  153. ct on quiBrakes soft on slow push but purfeck push???
  154. Replacement fuel hose for 22re
  155. Post oil pan replacement problems HELP
  156. Good source for Denso alternators?
  157. 3VZE cracked camshaft
  158. Bench Seats
  159. 86 22R Pickup shakes and shakes more when on drive
  160. 1987 22r Ssupposedly Rebuilt and maybe low Oil Pressure?
  161. 1989 pu - Clutch Master Cylinder Failure
  162. 3vze v6 4runner idle help
  163. A/c and Tach
  164. Desperately need help with oil leak!
  165. Worth fixing before selling?
  166. Fix or not before selling?
  167. Looking for information on a frame swap
  168. Looking for information on a frame swap
  169. recommended new seat covers
  170. 22re header/cylinder temp
  171. Towing with 2nd Gen (3VZ-E)
  172. Ford 9" swap
  173. 88 pickup 22 re ac fitting
  174. 1992 Pickup with Brake issues
  175. 94 4Runner SR5 V6 Manual Tx w/ ABS Hard Brake Pedal
  176. 22re Engine wiring plug location help
  177. Radiator Cap keeps leakin despite replacement
  178. Can I remove camshaft with pulley attached?
  179. New 2nd gen club member
  180. Electric fan swap anyone?
  181. Crunchy's flatbed build
  182. What bolt goes here?
  183. Rear axle shift?
  184. G144 axle differential: 4.88 to 4.10?
  185. Running Brake Lights Don't Work
  186. 1988 22R Running issues + Diagnosis
  187. Need a new hose..looking for the part number
  188. EFI fuse blowing Wiring Problems
  189. 89 4Runner starting issue
  190. 1993 Pickup Ext Cab 22RE - new owner w difficult questions & advice needed
  191. Weird intermitent no start issue??
  192. Changing original paint to a modern color. Yea or nay?
  193. Catalytic Converter Question
  194. 1989 Toyota Pickup
  195. Intake manifold cleaning
  196. truck been sitting for 2 yrs?
  197. Upper Control Arms.
  198. 92-95 3vze engine in 1991 truck?
  199. 88 4Runner 22re to v6 brake upgrade.
  200. Cooler lines 95
  201. 91 4Runner Transmission issues
  202. Antifreeze lines rusted on donor, how bad is the block?
  203. Heater will not turn off
  204. AC idle and nearly overheating
  205. 3VZE Rebuild: Piston-to-Bore Spec for Over-sized Pistons??
  206. 93 4Runner LSP & BV adjustment
  207. Rebuilt 3.0 VZE oil consumption
  208. power steering
  209. 1st gen. 4runner Sport seat foam/material inquiry
  210. Diagnostics Lights 1995
  211. 1994 22re Dropping Idle
  212. 3VZE Head Gasket Orientation
  213. 22RE Cooling Diagnostic
  214. 1994 AWD 3.0 Engine Rebuild or Swap Options
  215. Smittybilt Tube Bumper: Pickup vs 4Runner
  216. Trailgear SAS'd 4Runner - 63" rear springs low
  217. Timing on 22RE
  218. 1986 Toyota Pickup 22RTE / Manual Restoration
  219. Radiator water leak
  220. 91 Runner pulling sharply to the left when braking
  221. 93 4x4 22R check engine light
  222. 89 pickup 3.0l v6 3vze
  223. period correct tonneau cover
  224. 89 pick up A/C relay failure.
  225. EFI fuse kill switch
  226. ISO 22re guru reseal tips and tricks
  227. 94 DLX 4WD wierd speedometer!!!
  228. Looking for original bottle Jack arm thingy
  229. Propane auto trans question
  230. Anyone ever use POR-15 on Rocksliders?
  231. Ignition coil help
  232. More problems
  233. Speed Sensor, Speedometer Issue 95 4Runner
  234. Shop in sacramento for head gasket
  235. How did this happen, bent distributor rotor
  236. factory '06 e-locker in a 91 axle housing... just checking
  237. 94 pick up clutch replacement
  238. 3vze radiator cap problems?
  239. 1991 pickup R150 oil recommendations?
  240. 93 toyota 4runner 3vze idle issue please help
  241. Talk me out of buying this 3rz swapped 87 pickup
  242. Cracks on Auto transmission case
  243. Engine seize
  244. Ball Joint Brands?
  245. Valve clearances and adjustment
  246. Locker Questions, Pimp out the rear before touching the front? Snow wheeling?
  247. HELP 22re broken vacuum nipples
  248. What size catalytic converter?
  249. Possible alignment issue after lift
  250. Best fitting seat covers for 95 pickup
