factory '06 e-locker in a 91 axle housing... just checking
Old Jun 24, 2020 | 02:31 PM
Genera_lee's Avatar
factory '06 taco e-locker in a 91 axle housing... just checking
I was just offered the opportunity to get a factory e-locker out of an 06 tacoma for, what is colloquially, hella cheap. so i bought it.
i did my research and am pretty confident that it will fit in the rear end of my truck, a 91 4x4 pickup, 4cyl, 5 speed. based on what is listed on 4x4wire it should fit with some modifications to the axle housing, which im fine with.
can someone verify an 06 tacoma 3rd will fit (with those modifications) in an axle housing from a 91?
thanks
Last edited by Genera_lee; Jun 25, 2020 at 09:52 PM. Reason: title name for clarity
Old Jun 24, 2020 | 02:59 PM
irab88's Avatar
An '06 what? Might be some useful info here:
https://www.off-road.com/trucks-4x4/...wap-54205.html
Old Jun 24, 2020 | 06:53 PM
Genera_lee's Avatar
haha oops thanks for the opportunity for more info. edited above post to reflect. a 2006 tacoma 4x4 limited is what the axle is out of. had a buddy offer it to me
Old Jun 24, 2020 | 06:57 PM
Genera_lee's Avatar
thanks for the link. i had not seen that one. i'll look into before asking more questions
Old Jun 25, 2020 | 07:20 AM
Yotard's Avatar
Yeah it will fit but you have to grind the housing and weld up a couple bolt holes and then drill and tap a couple of new bolt holes for the longer stud that goes on the locker motor. It's easier if you take the axle housing off the truck to do it.
Old Jun 25, 2020 | 07:33 PM
Genera_lee's Avatar
yep i knew i had to do that to the housing.
thanks for confirming it. i'll be pulling it out of the housing tomorrow
fierohink
Apr 13, 2018 10:38 AM
scrpydoo8
Apr 22, 2011 07:51 AM
Chainlink
Jun 2, 2008 03:13 PM
Bill
Mar 9, 2007 06:09 AM
BajaRunner
Jan 25, 2006 12:11 PM
