Fuel Pump Swap on '86 22R
Old Aug 14, 2020 | 12:07 PM
Tims86Toy's Avatar
Just wanted to give you guys a heads up on the mechanical fuel pumps on the market. I had rebuilt the top end of the motor a few months back and also rebuilt my carburetor. I kept chasing problems with the carburetor and would up switching between 3 different ones. Finally I built one good one out of all three. Unfortunately I still had problems. I checked the fuel pressure on what was supposed to be a new fuel pump and found it running at 8 psi. That's more than double the pressure it should be. I already had a 2.5-4 psi @ 30 gpm electric fuel pump that I bought for the lawnmower. So far so good.
It looks like it belongs there.
File Type: html
Old Aug 14, 2020 | 12:51 PM
Dr Phat's Avatar
This isn’t a question to question your decision but what’s wrong with using the mechanical fuel pump?
Old Aug 14, 2020 | 02:14 PM
Tims86Toy's Avatar
It was running 8 psi. That's way too high and causes the carburetor to be unstable. Random high idle speeds as he fuel gets pushed by the metering rod.
Old Aug 14, 2020 | 02:17 PM
Dr Phat's Avatar
Oh my bad, glanced over that part while my morning coffee was still kicking in! I thought you replaced one electrical with another. I had a 22R but never bothered to get in running on gas, went straight to propane!
Old Aug 14, 2020 | 07:45 PM
swampedout's Avatar
5 Year Member
A lot of people use an external pressure regulator bc its so hard to find a pump with proper psi. But maybe thats just for electric pumps?
Looks great!
Old Aug 15, 2020 | 04:34 AM
old87yota's Avatar
No, that fuel pump does not look like it belongs there.
You shouldn't have a problem with a factory replacement pump. The Aisan carburetors use a little higher fuel pressure than most aftermarket carburetors such as a Weber.
Old Aug 15, 2020 | 11:59 AM
Tims86Toy's Avatar
Looks great!
I looked at installing a regulator on the mechanical pump but they were $50-75. I wasn't spending that money when I had an electric fuel pump sitting on the shelf. I bought that mechanical pump back in June of 2019 and it has less than 1000 miles on it. So back to AAP it goes for a new one. I'll keep it for a backup. After I test it.
I think it looks great bubble buster!
What's a little higher? Where did you get a design from? I don't remember seeing anything for a design on the Aisan's. The only thing I can find is listed on the new mechanical pumps at Rockauto and they state 3.5-4.5 psi @ 20 gph (1,800 rpm).
Old Feb 18, 2024 | 03:42 PM
thegerb05's Avatar
Electric fuel pumps are meant to be mounted as close to the gas tank as possible because they like to push fuel, not pull.
warmonger88
Jul 25, 2018 07:35 AM
boostlover07
Apr 24, 2011 08:35 AM
ToyotaLee
Engine Swaps
7
Nov 21, 2010 10:43 PM
yotaman90
Dec 13, 2007 07:53 AM
