Pre 84 Trucks 1st gen pickups
Fuel pumps keep leaking 22r
Old Jul 24, 2018 | 04:27 PM
warmonger88's Avatar
So I rebuilt my top end a few years back, 4 years I think, and I've just had my third fuel pump take a steaming dump. I could smell raw gas super bad on my way home from work today and found fuel dripping steadily from the pump. no leaks on the fuel lines though. I have an early 22r with a weber 32/36, standard mechanical pump, and a Holley Pressure regulator. Could it be the regulator putting too much back pressure on the pump? I have a return line still hooked up as well. The regulator has only been in place since last fall and I haven't had any other fuel issues since I installed it.
Old Jul 24, 2018 | 05:00 PM
akwheeler's Avatar
I have heard of cases where a shim is needed between the block and the fuel pump. there may have been one stuck to the original pump when you first replaced it.
Old Jul 24, 2018 | 06:28 PM
old87yota's Avatar
Like Akwheeler said, a common cause for these mechanical fuel pumps failing prematurely is the lack of a spacer / insulator between the head and the fuel pump.
Without the spacer / insulator, the pump arm gets over-extended and wears out the pump pretty fast.
I doubt the regulator is causing the problem, but I do not have any experience using a stock fuel pump with a Weber and a regulator.
Do you have a spacer / insulator installed (part reference: 23100C) ?
Image source: https://parts.toyota.com/
Last edited by old87yota; Jul 24, 2018 at 06:33 PM. Reason: Resized Image so it is more readable
Old Jul 24, 2018 | 06:57 PM
L5wolvesf's Avatar
Re the spacer thing - I kinda recall from another post that there are 2 different spacers - 2 different widths.
Re the 32/36 what pressure are you running?
Old Jul 25, 2018 | 07:35 AM
13Swords's Avatar
5 Year Member
The OEM spacer is no longer available new (at least from the parts sources I have), but Rock Auto is showing a few available:
https://www.rockauto.com/en/catalog/...mp+spacer,6252
I agree with old87yota, you may be missing the spacer & that's wearing the pumps out fast. BTW there are supposed to be 2 gaskets, one between the head & spacer, & one between the spacer & pump flange.
saltandgranite
Apr 2, 2013 06:47 PM
axelgrease
Apr 15, 2010 04:32 PM
4runnermax1
Jun 4, 2007 03:13 PM
Silverunner
Dec 30, 2006 06:18 PM
TOR
Jun 23, 2003 08:22 PM
