Keep Blowing Power Steering Pumps
Old Jun 4, 2007 | 12:54 PM
4runnermax1's Avatar
91 TOYOTA PICKUP 3VZE
MY truck keeps blowing power steering pumps they last for about two weeks then give up... I've put 3 pumps on so far and replaced the pulley the third time... Works fine until they blow what apears to be the rear seal. The last time my brakes started to make grinding noises just before it went out, but now that its out theres no noise...
Old Jun 4, 2007 | 01:47 PM
4runnerx3's Avatar
Get your alignment checked.
Old Jun 4, 2007 | 02:01 PM
JEBSR5's Avatar
There are 3 seals (O rings) that are the same size on that pump. The one on the back is a special compound, if you are using rebuilt units that may be your problem. If using Toy used or new, then not sure what could be going on.
Old Jun 4, 2007 | 02:13 PM
paxil4x4's Avatar
Drama Queen/Banned
Have you flushed the system?
Old Jun 4, 2007 | 03:13 PM
mpierson's Avatar
I would say take it to a shop, where they can put a hydraulic pressure gauge on the system. They should be able to pin point the problem.
Your brakes were most likely grinding because the P/S provides power to the ABS system.
You may have a clog in the system that is causing the pump to build up excess pressure before the bypass valve.
Did the P/S work alright after you changed out the pump?
Doug4320
Mar 24, 2018 10:11 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jonny246
Jul 12, 2015 04:51 AM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
