Diagnostics Lights 1995
Old Jul 1, 2020 | 08:00 AM
budgetcut's Avatar
So I have no transmission codes or OD Light when operating the vehicle and running. The O/D light blinks on-and-off-and-on-and-off etc when I jump the diagnostics so I can read my engine codes. Is this normal, or is the flashing O/D in diag mode bad? I was told that if the OD light was flashing the same way as the engine light does with giving numbers it would give a code. The O/D light just blinks with no stopping in diag mode, so there are no code numbers to read. 1995 OBD I.
Old Jul 1, 2020 | 08:33 AM
scope103's Avatar
Flashing twice/second is "operating normally." http://web.archive.org/web/201408161...31diagnosi.pdf
You probably have the A340H; it should be listed on the door pillar sticker.
Jeff Bouchard
Sep 28, 2017 06:28 PM
DupermanDave
Jun 14, 2016 06:25 PM
Ramrod00
Nov 27, 2012 06:13 AM
Tman100z
Mar 5, 2012 12:41 PM
