Radiator Cap keeps leakin despite replacement
Old Jul 10, 2020 | 10:26 AM
HelenaToyo42's Avatar
First time caller long time listener. I am a bit flummoxed on this particular issue and could use a bit of insight. I keep replacing the radiator cap on my 93 toyo pickup 2.4L 22 RE and after a bit of driving the cap leaks around the top. I have replaced the cap twice and this issue still occurs. Fluid is clear and was recently flushed. I am starting to suspect something about the overflow lines, tank, cap etc. I included some pictures which don’t show the actual leaking but may have use.
Anyone have this issue ?
Old Jul 10, 2020 | 11:22 AM
Co_94_PU's Avatar
Maybe try a Toyota part instead of the parts store universal?
Old Jul 10, 2020 | 11:50 AM
old87yota's Avatar
I agree, as long as the Toyota radiator caps fit the aftermarket radiator.
A few people on here have had problems with the red lever universal radiator caps.
Old Jul 10, 2020 | 12:18 PM
snippits's Avatar
My 92 22RE has an Advance Auto CarQuest radiator cap that's been working fine for about four years now on a CarQuest Spectra Premium radiator.
The plastic radiator could have a hair line crack.
Old Jul 10, 2020 | 12:19 PM
That’s a good call I will order a Toyota cap and come back with the results.
Old Jul 10, 2020 | 12:22 PM
I hope it’s not cracked, but I will check for that as well.
Old Jul 10, 2020 | 12:24 PM
Blueman's Avatar
I use the factory Toyota cap on a CSF 2306 (three core) radiator and it works fine. Or "Stant 10227 Radiator Cap - 13 PSI"
Old Jul 11, 2020 | 10:50 AM
Co_94_PU's Avatar
We kind of skipped over a few steps in the process here didn't we..
​​​who what where...
Are we talking like leaks puddles, venting pressure, or ?
Old Jul 11, 2020 | 11:19 AM
After driving some where it starts trickling coolant out of the top around the cap. Not a ton there’s still some in the reservoir but the reservoir is down.
Old Jul 11, 2020 | 12:53 PM
New radiator cap without the release solved it thanks for the help y’all
Old Jul 11, 2020 | 07:49 PM
5150 DAN's Avatar
Radiator cap
I had that same issue ! Replaced radiator and that solved it !
Dilomski
Jul 23, 2020 11:06 AM
sdoolin
Dec 1, 2013 05:23 PM
jstluise
Jul 30, 2013 11:49 AM
EricH87P/U
Mar 24, 2010 05:48 PM
irbigbird
Feb 6, 2007 10:44 AM
