Radiator Cap?
Old Nov 30, 2013 | 09:43 AM
sdoolin's Avatar
Radiator Cap?
Looking for a replacement Radiator Cap, mine leaks. This is an aftermarket radiator on of the ones with the plastic tanks. I am not sure what brand it is.
This radiator takes a larger sized cap than both of my other Yotas. The cap I have - which is junk - is 2 1/4 in diameter, the OE cap is 1 3/4 in diameter.
Since "parts guy" at parts stores don't really know anything about cars any more (they can only find you a part if you can tell them the year/make/model) I am having trouble. When they search on my vehicle (87 4Runner) they always only return a single cap, and it is too small. I gotta believe there is a cap out there that will fit.
I have searched the forums and I have seen discussion about Stant 10329 vs Motorad T13, but I could not conclude from my searches what part number I might need.
LC engineering references 2 different sized caps, and I could order the "larger" cap from them, but then I'd hafta pay shipping and it'd be a week.
Any and all help appreciated.
Old Nov 30, 2013 | 10:22 AM
chefdave's Avatar
Hi
had same prob on my v6 toyota. toyota listed one did not fit. so went on ebay found rad cap specialist. sent him cap diamentions £9 later with delivery i got a new well made rad cap.
Old Nov 30, 2013 | 06:39 PM
LITLRED's Avatar
Mine is a Motorad ST13 about 2.25 in across. I had to pinch the ears a bit so it wouldn't leak.
Old Dec 1, 2013 | 06:19 AM
sdoolin's Avatar
Pretty sure that is the same cap I have. I pinched down the tabs ever so slightly yesterday and all is good (for now).
Old Dec 1, 2013 | 05:23 PM
benja455's Avatar
Make sure the pressure is the same as factory specs (13 PSI), when I needed the larger radiator cap they gave me a 16 PSI cap and it caused all sorts of problems.
the1998sr5
15
Jul 14, 2020 08:35 PM
JaredL
Mar 28, 2016 09:08 PM
zombie_stomp
Aug 30, 2015 10:26 AM
ManzDaKlown24
Aug 22, 2015 10:25 PM
TJWilly
Jul 31, 2015 02:05 PM
