How did this happen, bent distributor rotor
Old Jun 25, 2020 | 07:18 AM
scott_schulz's Avatar
Hey guys, I just got a new distributor cap and rotor from LCE Performance and I just pulled the cap the other day and the rotor was all bent out of wack. It was installed correctly and I couldn't tell when it happened. Has this been a problem for anyone else?
Old Jun 25, 2020 | 10:49 AM
scope103's Avatar
I've never seen that, but it sure looks like you had the cap slightly cocked when you first put it on. Then one of the contact pins pushed down on the tip of the rotor.
I assume it ran. Well?
Old Jun 25, 2020 | 03:10 PM
It was running smoother with the newer parts but I am still trying to track down why it was jumping timing at idle 4* to 8* and all over the place, the new cap and rotor didn't seem to fix it. I guess it must've been not on totally straight when I ran it but I think I have the knowhow to put it on correctly.
Old Jun 26, 2020 | 07:20 AM
slacker's Avatar
how are the distributor shaft bushings ? I have seen warn ones cause this , any play in the shaft ?
Old Jun 27, 2020 | 04:49 PM
not much, a minute tap is heard when wiggling
Thkpage
Mar 27, 2017 01:37 PM
ChinkTruck
Dec 22, 2016 07:24 AM
rondog331
May 9, 2011 06:08 PM
magicninja
Jul 5, 2008 08:07 PM
MAXIMUS1968
Dec 18, 2007 07:02 PM
