- 91 pickup blown engine repair
- Cracked exhaust
- Replaced fuel pump/filter/lines...now too much gas???
- 35's or 37's?
- 1988 2WD pickup 4'' lift
- Looking for budget stereo/speaker options
- Need fuel pump lines help!!!! 91 3vze 6 cyl
- 87 4runner gas tank size ?
- High Speed Vibration
- 90 vs 94 4Runner parts interchangable?
- any ideas on here? would like a lil more power
- Matt16 Aussie?
- could a diff breather cause diff leak?
- 3VZE: TPS, Dashpot, Throttle Opener Mystery
- need a coulpe plugs from 22re harness
- Vacume hose missing and in plugged.
- What is this part?
- Door lock driving me nuts...
- HELP! TPS adjustment problems
- rear window sensor--tail gate problem
- Where is the coolant going?
- shocks
- No Brakes = No fun, no clean pants.
- Need a little help...
- VAFM restriction. real or imagined?
- Bud Built Ground clearance?
- Clicking from the dash
- A few questions about AC, Stereo and Spedo
- average cost of headgasket replacement??
- Cheep Hella's!
- CB problem..
- And On The Seventh Day I Will Rest
- I need some advice 22r alternator problem
- 22re performance motor
- Craigslist find 95 4runner $900 boston
- 86 Xtra Cab Axle Question
- 22re won't start on a hill...
- Help with #5 Plug
- miracle "auto" fixed itself (help +/or your story)
- Starting issue
- do you ever get tired of putting money/time into your yota??
- Where can I buy a good starter ?
- vacuum leak, and idle up valve half missing ??
- A/C stops working at idle
- Aggravating search for upper ball joints
- May be soon leaving yotatech...
- Trail gear ceramic clutch
- Totally off topic- music video with toyota
- LIFT with 15x10 wheels???
- Key wont turn ignition. Need help
- can you name these parts and their numbers?
- new shocks and oil WTF?
- Will this work?
- Tranny Won't Go In
- Great deal on PARTS. LETS DEAL!!!!!
- 2 inch suspension lift??
- newbie-89 hilux
- The Project begins
- 4 wheel drive question may sound silly but.....
- exploded diagram
- 2nd gen pickup rear window removal
- Build almost done
- what causes this whine?
- Dirty Spark Plug "valley"
- Idle surges, only when a/c is on.
- 3VZE Oil Pan Baffle
- bad oil leak
- 91 toyota 4runner rebuild
- Ball Joints ????
- 347 V8 4Runner - Updated
- Guess what.....SUCKAS!!!
- Flowmaster Knockoffs
- 87' Pickup backfires trying to revv up
- timing problems
- Flowmaster 50 Series on my second gen
- '91 4-runner Clutch Master Cylinder replacement
- new/ rebuilt fuel pump + carb (where to buy)
- ADD front diff question
- Engine code 25 and 26
- alternate o2 sensor placement for '88 22re
- 11mpg good? i dont think so
- Code 21
- For Heavens Sake it RUNS IT RUNS I CANT BELIEVE IT.
- 1991 4runner rear seats
- Clutch Pedal looses pressure randomly?
- purchasing truck with power steering issue
- Guys I need help this is my 911
- Starts, But Doesn't Run!!!
- Another rear suspension question.......saggy rear end question.
- Oil seal blowout.
- Really I could use the help. I have no idea why it runs so bad.
- What do you guys think
- Driveshaft?
- 2nd and 3rd gen motor mounts
- wheel bearings...please help
- quick easy question please help will 89 4runner tranny fit in a 94
- Truck starts but needs tons of skinny peddle to stay running.
- vent windows
- WHOOO HOOOO The body is on but........??????
- O2 sensors Good price OEM Denso
- Tiny front speaker mod?
- 95 4Runner Problems
- dual battery mod for 94 3vze
- 87 22re in a 94
- Torsion Bars Question
- 95 4runner 3vze knock sensor problems
- 4x4 question
- 22RE Timing Chain no start
- What your timing set to on your 22RE??
- mystery connector under plenum
- Why is my runner eating 5spds?
- 1988 4x2 auto tranny
- R-12 to 134A Retrofitting...Please help. In AZ!!
- How serious is this damage?!
- To do or not do CV axle
- Oops?
- Can someone help me identify a 22re plug and parts
- Is this truck lifted?
- Dealer pricing on repairs '91 4Runner
- MANY MANY QUESTIONS????? Please Help
- MC reciever?
- Auto trans shift problem
- blowing "ENGINE" fuse
- New guy hesitation
- 2 In Lift With 35's?
- ADD vacuum lines
- 3VZ Manual 4x4 crossmember question
- 88 4runner Mud flaps. I NEED SOME!
- 4X4 noise
- truck idles ok cold, runs rough after warm-up
- starter troblem. i need help.
- Help Diagnose my Tranny
- 2wd 55mph rear vibration in intervals?!!
- rear diff problem..leaks
- $45 Butt Lift
- Howling noise
- timing cover quest.
- Painting the 4Runner
- snapped CAT stud
- Power Steering Problems
- Should I buy a 1994 Toyota Pickup 4x4 Regular Cab Deluxe V6 SB
- please help!!!engine problem
- Driving 1,000 miles in my 88' toyota
- Simple quick hub question.
- lift spindles
- 95 3liter misfire
- how far should u torque. .
- how to tell when carb is bad
- RMS replacment
- Bumper help
- CV torque bolts
- Need diagnosing help
- A/C problem
- tools needed for ball joint, tie rod end replacement
- fuel in oil sump/ heard carb buzzing night before
- tricks to getting the front diff back on
- Interior lights, Clinometer installed. *pics*
- drive shaft replacment bolt and nut size
- what gets sealed?
- Okay I have the donor truck home and.........
- Rear 3rd member diff. engine swap question
- oil pump removed, but wait!
- Spacers/please Help
- 4wd shift on the fly?
- Rattling sound.
- is it possible for a 22r to 22re swap?
- wanted interior pics(seat covers)
- Front end Clunk/Pop
- Need Ideas 4 Exhaust: '89 4runner V6
- Fog lights mounted into stock bumper?
- Question about HG work at Dealership
- 22re Water Pump Torque
- 3FVE Swap (Which New Parts?)
- muffler
- 3.0 / 3.4 Power Steering Pump compatible?
- Cuphold Mod
- '84-'88 exhaust pics
- bought truck at toy dealer would they do maintanince?
- some minor body work questions
- piston ring question???
- 22RE idles erratically...
- 4x4 conversion 4runner
- What have you found in your oil pan?
- Thinking about waterproofing my interior
- Air Tight 4Runner?? Probaby Laughable...
- quick question
- calling all 22rte owners
- 1995 4runner overheating, help!
- Project OD
- thermostat gasket glue
- V6 Overheated. Need help
- Starter contacts
- Inclinometer installed!!
- Squeaky clutch, and knocking.....
- 22re trouble code #31 problem
- BUSHWACKER QUESTIONS and pics wanted!
- How would one remove the rusted spare?
- "4Tops" 4Runner softops?
- Window glass clip
- oil pump removal
- how much can i haul?
- funky film on rims
- Slight smoke in exhaust. Change oil weight?
- wood getter
- Cat Converter Flange
- Factory Service Manuals vs. Haynes
- Grease for Aisin hubs
- 203HP 22re
- fuel filter missing???
- 22re cuting out
- Code 24/severe engine miss
- trail rig ( i know worng place)
- Need some input please, burning oil.
- OKAY GUYS I DID IT!!!!!!! Now I need your help
- repaint my truck
- Input Shaft stuck to Pilot?
- Where does your oil pressure needle sit at?
- I am baffled! 22re content
- New Truck Maybe
- surging 3.0 idle. fuel filter maby???
- diff diff stud questions
- '89 3.0 V-6, Hard to Start
- warning!!!! danger will robinson!
- HELP...excessive air when bleeding brakes
- chrome mirrors
- aussie locker model
- rear coil update and question, please!
- Clutch Sounds
- Installed tube doors on my 89 pickup from 4X innovations
- 4runner Build Question
- Total Paint job for a '88 pickup
- Weird Noises when turning
- 94 toyota 4runner problems
- Should I replace my timing belt?
- Todays progress
- engine replacement, timing off....
- 22re idle screw
- updates and hang ups: project drag
- electric shock from coil lead
- Hardtop side window re-install
- Emergency guy again!!!!!!
- 2wd and 4x4 rear leaf interchangeable?
- Won't Idle after sitting for two months
- Aussie Locker Oil
- ipod mod for sr5er
- 1st gen/2nd gen 4runner IFS poser flex shots
- Lets see your best off-road experiences! (or worst....)
- Friends are cool
- how much do i need to cut off first gen roll bar to fit gen2?
- First offroad experience
