Where can I buy a good starter ?
Old 07-21-2008, 01:40 PM
89 black toy's Avatar
I need a new/rebuilt starter. I dont want to change it every 2 or three months.
Old 07-21-2008, 01:45 PM
fillsrunner4's Avatar
NAPA sells them. Just keep your receipts so if it goes they give you a new one
Old 07-21-2008, 02:35 PM
anotherjeff's Avatar
Rebuild your existing one!
Old 07-21-2008, 05:31 PM
dcg9381's Avatar
It's usually the starter contacts, which are less than $10 to replace... See 4crawler's page..
Old 07-21-2008, 05:44 PM
skinnyhb's Avatar
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old 07-21-2008, 06:18 PM
toyota-erik's Avatar
You must be playing in the deep water eh?
Old 07-22-2008, 03:29 AM
No,I havent been playing at all in this truck.Just driving back and forth to work.It did sit outside for awhile when I had the engine out rebuilding it.How much trouble is it to rebuild one of these?
Old 07-22-2008, 05:18 AM
terrybo3's Avatar
The hardest part is getting it out. Then it's just a matter of changing the contacts (maybe 4 screws total).
Old 07-22-2008, 05:23 AM
dirtoyboy's Avatar
Originally Posted by fillsrunner4
NAPA sells them. Just keep your receipts so when it goes they give you a new one
That does a lot of good when you are in the middle of BFE!
Old 07-22-2008, 05:27 AM
Old 07-22-2008, 05:38 AM
dirtoyboy's Avatar
I know..I know...kids these days and their "terms"
http://www.urbandictionary.com/define.php?term=BFE
Old 07-22-2008, 05:48 AM
Yeah Thats what I thought
Damn kids
Old 07-22-2008, 06:15 AM
Why do you need a new starter in the first place? What are the symptoms? And, who changes a starter every 2-3 months?
Toyota starters are very easy to repair. The hardest part, as mentioned already, is just pulling the starter out. The contacts are super easy to replace. A dealership once told me I may want to consider replacing the plunger too, but I never have.
If you want to get by super cheap, you don't even have to get new contacts. Just remove the one that's worn, clean it off, and bend it ever so slightly so so the lip that touches the plunger sits a hair higher. I did that to a starter a year ago and it's still going strong. Mind you, I did this when it was 30 below zero outside, and on a weekend, and I didn't have replacement contacts in hand. It was intended to be a very short term temporary fix, but I let it go for a year before actually fixing it (and I could have let it continue to go).
Old 07-22-2008, 08:10 AM
I have never had any luck in the past with "rebuilt" starters or alternaters from Autozone and the like.That is what I meant by having to change it out every 2 or 3 months.
Old 07-22-2008, 08:23 AM
dirtoyboy's Avatar
I would rather use a used Toyota starter than an autozone unit (which I have seen a few that failed out of the box) My original toyota starter made it 225,000 miles before it gave up if that tells ya anything
Old 07-22-2008, 08:39 AM
scuba's Avatar
bfe sucks
Old 07-25-2008, 12:04 PM
terrybo3's Avatar
BFE is where all the good trails are...
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
ZONAYODA
07-13-2015 07:17 PM
Jonny246
07-12-2015 04:51 AM
crashburnoveride
07-10-2015 06:39 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: Where can I buy a good starter ?
