87 22re in a 94
Old Jul 17, 2008 | 10:28 PM
chadsc94's Avatar
87 22re in a 94
This kind of seems like a stupid question, but i'm about to buy an 87 22re in my 94 pickup that has a hole in the block. Will i run into any problems with aftermarket mods like header or anything else, when i look at headers it separates the years to 89 to 95....is this just cause emissions sensors or cause of that way it would fit in.
Old Jul 17, 2008 | 10:31 PM
DeathCougar's Avatar
It would be because of the emissions changes, and frame/body clearances.
As long as you only use the long block from the 87, you will be fine. A 22RE is a 22RE (strictly long block speaking)
Old Jul 17, 2008 | 10:37 PM
chadsc94's Avatar
its a complete engine, so i could pretty much cancel out a header for it?
Old Jul 17, 2008 | 10:39 PM
you cannot swap a "complete" engine. The intakes are different, as are the exhausts. Like i said, the long block is exactly the same ie Valve cover to Oil pan
Just swap the intake, wiring, etc etc from your 94 on to the 87 engine. Then the header will be fine!
Old Jul 17, 2008 | 10:55 PM
chadsc94's Avatar
good to know, i'm glad i asked...looks like i got a weekend full of work.
Old Jul 17, 2008 | 11:50 PM
scuba's Avatar
hmm, glad i read this.
ill be putting an 86 in my 91 soon enough
cant wait to get that little bugger back on the road
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
