ADD vacuum lines
Old Jul 16, 2008 | 11:52 PM
Matt16's Avatar
ADD vacuum lines
There are two ADD vacuum solenoids, a brown and a blue on the passenger's side of the engine bay, that connect to the two metal tubes coming out of the front diff. I forgot to mark them before they came off, so I am wondering if anyone knows which line connects to which tube, or would be willing to check.
Thanks
Old Jul 17, 2008 | 04:26 PM
Matt16's Avatar
bump.
Old Jul 17, 2008 | 05:46 PM
DeathCougar's Avatar
well there are only two possible combinations...so try it one way. If that doens't work to lock in your ADD, switch them. Pretty simple methinks.
Or just yank that ADD setup out and put in a diff from an 86-89
Old Jul 17, 2008 | 06:43 PM
Matt16's Avatar
THink that's what I'm going to do. Like hell I'm ever going to take the diff out again. Its a total pain to put back in. Besides, I honestly like the ADD. I leave my hubs locked in the winter thus I ADD is a good thing.
Old Jul 17, 2008 | 07:29 PM
904_runner's Avatar
Matt on mine the blue one was for locking it i think, and the brown was for unlocking. Maybe, i could be wrong. Jack up the front, and mess around with the lines, plug one in then, throw it in 4wd then spin one wheel, if the other one spins on the other side then your good to go! You get the idea!
Good luck
Old Jul 17, 2008 | 08:05 PM
RobD's Avatar
Did you just say you leave your hubs locked with your ADD system?
Old Jul 17, 2008 | 08:07 PM
904_runner's Avatar
Thats my little test to see if you have the right line plugged into the right location.
Old Jul 18, 2008 | 07:26 AM
Matt16's Avatar
In the winter, yes I leave them locked.
In the summer I unlock them to reduce wear on the CV boots and axles.
raptor510
Aug 19, 2015 02:15 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
