New guy hesitation
Old Jul 17, 2008 | 03:04 AM
js70c20's Avatar
New guy hesitation
Hi all, i'm new to this forum, (SORRY FOR THE SPELLING) I have a 94 extended cab pickup, 22R-e 4x4, totaly stock with 218k miles. Never had a problem till last week, I now have a hesitation that I'm pulling out whats left of my hair trying to figure out. Any advice would be GREATLY appreciated. I have a speratic low rpm hesitation, more common when to engine is under load. I first went through the electrical system (plugs, wires, cap , roter) no help. Then the vacuum lines, no cracks, cleaned the throttle body, no help. was thinking TPS because the problem seems more commen at a specific throttle possion, but not sure . Help Other than the hesitation the truck runs great.
Old Jul 17, 2008 | 03:07 AM
crews462's Avatar
how about changing the fuel filter?
Old Jul 17, 2008 | 03:37 AM
js70c20's Avatar
Fuel filter new 10k miles ago, but i'll try it Thanks
Old Jul 17, 2008 | 05:45 AM
Crawdad's Avatar
Had a very similar problem on my 3.0, ended up being bad gas (combined with fouled plugs and worn cap/rotor button). Poured in some water remover and filled the tank and it went away. Don't know if it applies to your situation, but it's worth a try. I used Iso-Heet, cost about $2 a bottle. You can also use 95% isopropyl alcohol.
Old Jul 17, 2008 | 08:26 AM
coryc85's Avatar
Also, check/adjust your valves and verify your timing. These are likely not the culprit if your symptoms are sudden, but at least you can rule them out. Also, if you cleaned and adjusted the TPS, you might want to reset the ECU.
Old Jul 17, 2008 | 09:38 AM
js70c20's Avatar
Thanks All
RatOmeter
Oct 22, 2015 03:17 PM
coffey50
Jul 28, 2015 10:55 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
timmJ
Jul 7, 2015 02:01 PM
colinmil
Jul 6, 2015 04:03 PM
