Is this truck lifted?
Old Jul 17, 2008 | 01:49 PM
BlackBox's Avatar
Disclaimer: I'm a super green newbie! And this may be the lamest question ever. I've searched around (actually been "stalking" this board, reading, learning, etc.) for a while now, and I can't find anything that would help me figure this one out. This might indicate that I already have my answer, but I figure it doesn't hurt to ask...
I need to know if my truck is lifted or not. It's a stock 88 4Runner, 22RE, sitting on 31x10.5x15 BFG AT/KO's with less than 1,000 miles on them. A good friend of mine suggested that it is lifted in the rear as I have very little rear sag, but this doesn't sound like very technical advice to me. I have 7" of clearance from the inside of the tread on my front tires to the bottom of my fender and 6 1/2" in the rear. The way I figure, as soon as I acquire a front bumper, most of the sag should be corrected.
(excuse the shoddy pics, this was taken at work with my camera phone)
Here are a couple of pics of my front suspension (and parts that need to be replaced acutally just got new 1/2 shafts in the mail as I was typing this):
The truck's not sitting level - it's leaning on the driver's side in my parking garage - but the angles look pretty "normal" to me. I would have taken pics of my rear springs (which are sitting almost parallel to the body) but the sun wasn't helping.
Anyone have any idea whether or not this truck is actually lifted or not? Or any suggestions as to how I might go about figuring this one out? I do kinda feel like an idiot - but ah well. Thanks for your help.
Old Jul 17, 2008 | 01:52 PM
904_runner's Avatar
Well if its leaning toward one side in the front, my first thought was previous owner cranked torsion bars unevenly, but there is no lift brackets on that to my knowledge. Looks stock from here
Old Jul 17, 2008 | 01:59 PM
Jay351's Avatar
Looks stock to me. Lets see a picture of the rear leaf pack and shackle....
Old Jul 17, 2008 | 02:00 PM
BlackBox's Avatar
Thanks. It's actually leaning because that's the side of the parking garage that slopes up/down. It doesn't lean when it's on level ground.
I didn't see any brackets or anything either. My guess is that I just got lucky.
Old Jul 17, 2008 | 02:07 PM
904_runner's Avatar
Oh, thought you meant on flat ground it is leaning.
Looks stock!
Old Jul 17, 2008 | 02:09 PM
BlackBox's Avatar
I'll take pics of the rear tonight when the sun goes down a bit.
Old Jul 17, 2008 | 02:13 PM
4Crawler's Avatar
See:
- http://www.off-road.com/trucks4x4/ar....jsp?id=398514
Most trucks and 4Runners are set at the factory to about 13.5" - 14" from the top of the rim to the fender lip.
Old Jul 17, 2008 | 02:14 PM
abecedarian's Avatar
looks stock to me. it may just be that the 4runner was never used as a truck so the rear isn't sagging much....
Old Jul 17, 2008 | 03:14 PM
other possibilities are that someone:
1) had the rear springs re-arched
2) installed an add-a-leaf kit, load helper springs, or air bag helpers
3) installed air shocks
4) installed new or used rear springs, either stock height or with a slight lift
5) installed longer rear shackles (an approximate 2" rear lift shackle often levels the vehicle out for a mere $40)
6)short lift blocks (unlikely)
7) or, like has been previously mentioned, you just lucky and have a level headed truck.
As for the front, I don't see any signs of the typical drop brackets used with the 3-4" suspension lifts, and I see stock control arms.
1) torsion bars could be cranked up (or down)
2) aftermarket torsion bars installed (normally stiffer but do provide some lift)
3) you might have upper ball joint spacers (usually provide 1/4" lift)
4) air shocks
That's about all that can add lift to the front of an IFS vehicle.
Mind you, listing these items doesn't mean I think your vehicle is actually lifted or has any of these. Basically, any stock height vehicle could have any of these options done. You just never know. If you can provide pictures of the rear springs and rear shackles, it may help determine what you have.
Old Jul 17, 2008 | 03:18 PM
4) air shocks
I'd say the front has no crank on the bars: look at the gap between the compression stops and the lower arm, and the arm is almost horizontal.
Old Jul 17, 2008 | 03:31 PM
InternetRoadkill's Avatar
Mine has new springs. It's at the factory height for an 88.
Old Jul 17, 2008 | 03:33 PM
ozzydg55's Avatar
looks like a possible body lift
Old Jul 17, 2008 | 03:36 PM
here's a 4" suspension lift on an 88 with 265/75r16 tires (just over 31" diameter):
yeah, it's my truck. so you can see how much room is between the upper wheel and fender lip with a lift.
6th Gear
19
Dec 10, 2019 07:31 AM
live4soccer7
Sep 3, 2015 12:29 PM
duckhead
Jul 17, 2015 04:45 AM
Tommy T.
Jul 5, 2015 07:48 AM
88Toy
7
Jun 17, 2015 09:40 AM
