electric shock from coil lead
Old Jul 12, 2008 | 12:30 PM
ahickman's Avatar
I have an intermittent hesitation or flutter on my 94 22RE and was going through a few suspect areas this morning. After taking off each ignition chord and ohming them out, I put them back on and fired it up, opened up the throttle and wiggled each cable to see if there was any intermittent behaviour. When I pressed on the top of the plug at the coil, I got the snot zapped out of me. I thought for sure I had found the culprit, but cant find any cracks on the coil or the cable/boot. So I swapped end for end on the cable to see if it was the boot or the coil. Got zapped even worse!
Anyone have any input as to whether this is "normal". My gut says absolutely not, but I have been wrong before. If not normal, would this indicate the coil pack was "leaking" charge (e.g. cracked somewhere)?
I don't have another coil or plug to swap out. Suggestions?
Aaron
Old Jul 12, 2008 | 12:32 PM
abecedarian's Avatar
you again? lol, j/k
are you getting the wire end all the way down into the coil tower?
try working the boot up the cable and using a small screwdriver to force the terminal all the way down.
Old Jul 12, 2008 | 12:48 PM
ahickman's Avatar
Well, I just felt so good about myself today that I though I would offer you or thook a chance to bring me down a notch.
Pretty sure the crown is seated deeply. Just to be sure, I pushed the blade of a screwdriver down on the rubber cap and felt no further movement.
I know the voltage is pretty beastly (50K Volts) coming out of the coil, but can't quite convence myself that it should be able to arc through the plastic housing or molded cap unless there was a exposure somewhere.
Old Jul 12, 2008 | 01:29 PM
lol... anyways, I don't think that's your problem. even though the spark did arc to your finger, there's no evidence it's arcing to the coil case.
how's the humidity today?
Old Jul 12, 2008 | 01:52 PM
ahickman's Avatar
Virginia = 100% humidity
BTW, do you know off hand what the resistance should be for a coil wire (coil to distributor)?
Old Jul 12, 2008 | 02:03 PM
myyota's Avatar
Your coil probably has a crack in it and thats why your getting zapped, and thats probably whats causing all or part of the hesitation your getting. the crack can be so small that you may not be able to see it. it might be a good time to give your ignition system a tune up with new coil, spark plugs and plyg wires.
Old Jul 12, 2008 | 06:15 PM
Matt16's Avatar
Aaron
You are so freaking lucky your penis was not the closest thing to the metal bumper (ground).
Old Jul 12, 2008 | 06:45 PM
ahickman's Avatar
Poor man's version of Viagra discovered?
Old Jul 12, 2008 | 08:00 PM
We will need you to test that hypothosis before we can continue research.
Old Jul 12, 2008 | 08:13 PM
thook's Avatar
Um....yeah, go ahead and try that for us all, Aaron. Can't say I'll be likely to join you on that expirament, though. However, I'm sure Abe will be excitedly first in line to follow suit. I'll have your sign waiting for you...lol!
All I can say is you shouldn't be getting zapped. It gets pretty humid here, too, and I've never been zapped. A crack sounds plausible, but I'd have to look more into that kind of problem before I could totally support it.
Yeah...I know. I'm just no help. Atleast I had the chance to jab Abe once again. My day is complete now. Yippee!
Old Jul 12, 2008 | 08:14 PM
I must admit... I'm feeling rather much like a pin cushion lately.
Old Jul 12, 2008 | 08:22 PM
CyMoN's Avatar
LOL that could become a quote on someones sig
Old Jul 12, 2008 | 08:41 PM
thook's Avatar
I think myyota maybe right. I did some reading and that would explain your symptoms.
Here's the FSM testing and resistances...
http://personal.utulsa.edu/~nathan-b.../4onvehicl.pdf
Old Jul 12, 2008 | 09:53 PM
Matt16's Avatar
That's what she said.
Old Jul 12, 2008 | 09:55 PM
Matt16's Avatar
We are going to hear about this in the news- from the hospital.
Old Jul 12, 2008 | 09:59 PM
No one has ever said that to me... (out loud at least)
I have no comment here.
Old Jul 14, 2008 | 05:51 AM
Junkers88's Avatar
LOL!!!!! Well I'm glad to know it isn't just me that's done that.
Old Jul 14, 2008 | 06:10 AM
Crawdad's Avatar
I got zapped on mine the other day. Brand new Denso wireset, new dist. cap, everything was on good and coated with dielectric grease.
Unfortunately, I was wearing a wet bathing suit. And guess what part of me was leaned on the bumper.
My hand and arm took most of the shock. My weewee just tingled a little.
It wasn't bad, actually, and it was cheaper than going on a date... hm.
Old Jul 14, 2008 | 06:20 AM
Junkers88's Avatar
You know I'd laugh a lot harder about this except I'm still having bad dreams about the time I tinkled on an electric fence while dove hunting.
The hunting stopped for the day.
Old Jul 14, 2008 | 05:35 PM
leebee's Avatar
ya lern sumn new ever day, yup!
thanks for making my day guys and i dont mean to laugh at your 'experiences'!
lee
