PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 [160] 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Rear door speakers? 1991 4Runner 4-door
  2. Size bolt fits in top rollbar hole of 4runner?
  3. injectors not truning on
  4. T-Case issues
  5. How hot does manual tranny get? Rear main seal problems??
  6. AC Evaporator Box
  7. Land Cruiser Springs for my 91 runner 3vze
  8. Clutch installation - backwards?
  9. Lock-rite lockers just installed
  10. grill guard mounting
  11. Wiring Harness Swap
  12. 1990 Runner V6 Fan Shroud?
  13. What part is this called?
  14. Rough idle/gutless problem solved!!!!!!!!
  15. 95 4Runner Seat Covers
  16. corner light
  17. 87 4runner drive shaft
  18. Low idle and stalling at low rpm's
  19. how long does it take you folks to remove and install U joints?
  20. howling problem
  21. overheating due to lean condition?
  22. chirping noise--wheel bearing? tie rod end?
  23. Power Window Harness
  24. I did it Auto to Man Swap. But have a code 42
  25. 1st 2nd generation or 3rd generation
  26. Transmission Removal!
  27. Oil in coolant?
  28. 88 truck and 4runner Factory service manual link
  29. t-case not engaging 4L
  30. 22RE NEW on ebay?
  31. Coolant loss 22re
  32. Bored 40 over do I need to mess with anything?
  33. 95 3.0 help
  34. No power.. at all.
  35. Driver's side power mirror for a 1993 SR5 truck.
  36. U joint or yoke problem
  37. Beware of the almighty slave cylinder!
  38. Blown Headgasket- It CAN happen to you
  39. 22re overheating issue
  40. Noob question regarding 4x4
  41. Hurdles to building a high power 22R-E?
  42. baja style bumpers for a 88
  43. A/C problem
  44. 3VZE swap help
  45. my cv joint is twisted and i have a whining sound
  46. Megasquirt on 3vze
  47. Anyone Have the link to Rear window Repair Write Up
  48. ignition switch
  49. I'm curious... 22re HP/Torque question...
  50. Witch Hunter Performance ROCKS!
  51. Flexing the $84 dollar 33 BFG MTS!
  52. How does this combo sound?
  53. Grinding Popping / Binding sound IFS
  54. 86 22re 4runner
  55. Rear Window Switch in Cargo Area
  56. running hot
  57. Wierd clutch
  58. Where is the fuel pump relay on a 1990 4runner?
  59. Rebuilding a 22RE - Some Questions.
  60. Which size of wheel should I get
  61. Flex a lite 165 or 180???
  62. Line-Xed!
  63. Fixed Oil Leak, but now running rich.
  64. Junk yard score
  65. 1986 Turbo Hilux 4x4
  66. rubbery foam stuff
  67. hissing intake - floppy idle
  68. Reliability???
  69. E Bay 6 puck Ceramic clutch kit
  70. torsion help
  71. i need to get my tailgate off
  72. Um what is this 22re part i looked at bleeders pics
  73. Transmission removal woes...input shaft siezed?!
  74. 93 4runner oil problem
  75. New bfg km2 pics!!!
  76. 22re+5speed+4.10gears+tire size?
  77. bad idle everyone please read
  78. junkyard lift kit?
  79. New Rims and Tires for my Runner.
  80. my 1986 extra cab pick up is slow!!
  81. What is the best value about Idler Arm?
  82. What Year 3VZE
  83. what is this leaking from my front end (with pics)
  84. Leaking Fluid from Passenger Rear?
  85. 3.0 issues
  86. Do I need a new water pump?
  87. LC Engineering brake rotors
  88. Magnaflow 11225, you guys like them?
  89. Oil blow by
  90. I need help rebuilding my 3.0
  91. Need help on exhaust
  92. A way around LC Engineering super expensive dual row conversion?
  93. winch help
  94. new axles
  95. spare tire
  96. PU Hood Scoops / Aftermarket Hoods
  97. 90 yota pickup 22re and it wont start replaced the fuel pump
  98. bj spacers coil spring spacers
  99. Frame repair
  100. help me out i need an ecu pic out for a 94 4runner 3VZE
  101. New truck :)
  102. Starting question
  103. No oil in filter??
  104. 4" 95 Runner Suspension Lift(s)
  105. can you run rear springs from an 85 in a 94
  106. I got my CB installed
  107. 1990 V6 SR5 head gasket recall - cracked head?
  108. 22re timing chain
  109. tacoma 6 speed into a 94 pickup
  110. Photo Request
  111. Donor engin for my 89 22re
  112. wyoming shadetree needs advice
  113. Snorkel with 3.4 swap?
  114. Burnt Trans Fluid
  115. Frame swapping ideas
  116. New meats for the summer!
  117. 1990 toyota RV no spark!
  118. My noob ISR.
  119. Steering relay rod recall question
  120. Diff Trans fluid?
  121. Pulled some codes..
  122. FYI: AFM adapter plate for "cold air"
  123. Stealth Snorkel (pics)
  124. missing my tranny mount bolts. anyone know what size??
  125. Removing interior door handle?
  126. will they fit alright?
  127. Axleshafts keep snapping
  128. toytec lift madness!HELP!
  129. 88 4runner wiring problems.. help
  130. who else has a 2 door?
  131. 4inch drop bracket lift 2 months ago and my front differential is now bad
  132. relay help!
  133. my dad is wanted to lift his toyota after helping me complete my sas swap on mine
  134. To 3VZE or not to 3VZE? Thats the question
  135. blown head gasket - how far should i go?
  136. Part # ? Air Mass Meter/ Sensor for 4Runner
  137. 3vze Transimission removal?
  138. New paint job suggestions
  139. E-brake light flahses on when E-brake is off
  140. early 1995 4runner v6 swallowed water need help please!!!
  141. Front diff
  142. TOB Question
  143. 1995 3vze Timing belt removal and replacement "With Lots Of Pics"
  144. Anybody every tried a carb on the 3.0?
  145. Planning for a new exhaust system
  146. HELP! Missfire/crappy running?
  147. 1987 Rear Window Problems :(
  148. loud exhaust
  149. how to lock up the rear on a 92 4runner?
  150. Stuck in the mud pics!
  151. 3vze TPS voltage check VTA-E2.
  152. does anyone actually wheel their truck with 33x12.5 and ome coils?
  153. 22RE Troubles - Code Reader gives me a code 51
  154. Fuel Pulse Damper ?
  155. Total brake failure
  156. anyone found an antidote for clicking under the dash?
  157. No more 86 pickup. :(
  158. 89 22re fuel problem NO START HELPPPP!!
  159. Cheapest Lift?
  160. 1986 pickup sr5 mirrors
  161. wheel alignment specs after lift
  162. Steering knuckle/ CV shaft bushing? anyone deal with this before?
  163. Exhaust leak questions
  164. 4runner strapping out a GRAVEL TRUCK
  165. 5.29s and lockright installed!
  166. ARB Bull Bar and XRC8 installed.
  167. 93 Pickup stumbling bad, different from other stumbling problems
  168. rocker peck?
  169. Truck acting up
  170. plug 'n play mods
  171. Check Engine Light blinks 5 times then 11
  172. What helps quite motor noise the best??
  173. rear drive shaft
  174. Grad Money Burning a Hole in my Pockets.
  175. What was in original tool kit
  176. Best size tire/rim package?
  177. jerky, sluggish accel and idle.
  178. '91 Pickup rear suspension rebuild
  179. got a new truck!
  180. Is my ECM or ground bad?
  181. Center Link & Pitman Arm replacement (suggestions?)
  182. PS Pump Pulley -92 V6 4Runner
  183. Add-A-Leaf or new springs for rear?
  184. 1988 4runner that i want to put on a 1985 pick-up frame
  185. smog / air pump 1990 22r
  186. Has anyone upgraded a 1987 4runner brake cylider??
  187. Recommend me a cover for my '89 pickup, please
  188. wiring penetration through the cab for a light bar??
  189. something really wrong! bad stumble!
  190. 2 part question.(tire psi)...Pep Boys hates me...LOL
  191. tranny and dual t-case seem really hot
  192. No dash lights...any help?
  193. re-attached transmission, now truck wont roll
  194. Cleaned intake and throttle body now poor gas mileage
  195. LC Engineering MECHANICAL fan
  196. any tips on upper ball joint removal?
  197. Dashboard light on when car is off
  198. 7mge air flow meter lest see if the slow 6 can take it
  199. Loc-rite Lockers (help)
  200. '91 22RE starter removal
  201. air valve not working???
  202. where does this hose plug into.(pics).?
  203. Truck Wont start
  204. Bleed Gas to motor...3vze
  205. ? about codes?
  206. toyota elocker 3rd member
  207. 3vze Idler Pulley No. 2 (upper, big one)
  208. 3VZE antifreeze leak from hell - help!
  209. Little to no oil pressure
  210. Tailgate key wont put rear window down
  211. sliding glass window 95 pickup
  212. cant remove turbo from exhaust manifold
  213. need motor pics NOW!
  214. Fair Rollers wont fit on ARB!
  215. bucket seats?
  216. Clutch problem?
  217. Ever heard your fuel pump???
  218. '89 3.0 Power Steering Pump Rebuild Writeup
  219. 95-4Runner Engine Cleaning
  220. Front hub stud help
  221. Help! Passenger window issue
  222. Breaking news on 22RE noise
  223. 3rd member
  224. Best Junkyard Mods
  225. I want some 4.10 gears for my 2wd
  226. Slow battery drain?
  227. Polishing my intake - ocd can help sometimes lol
  228. Pinion seal fixed but still leaks
  229. A/T light comes on and stays on?
  230. Impossible Piston Ring
  231. 91 3.0 pickup blown head gasket? Help!
  232. 90's sticker removal
  233. 3vz rough idle
  234. 91 pickup 3.0 auto 4x4 ques.
  235. running in FWD
  236. trailer wiring
  237. how to get air out of coolant lines?
  238. 22r 22re heads
  239. mystery coolant leak
  240. break lamp help
  241. brake light problems
  242. 3VZE-Replace head gasket or swap in another engine?
  243. Truck wouldn't move...Help
  244. Exhaust systems
  245. Gearing and transmission questions.
  246. **89silverpu's e-locker retrofit build**
  247. Transfer case leak!!!! Help!
  248. 529 rear diff good deal?
  249. Oil in air intake tubes, 3.0 Why
  250. 95 3.0 Stumbling/hesitation
