3vze Idler Pulley No. 2 (upper, big one)
Old Jun 4, 2009 | 01:13 PM
jasonbrink's Avatar
The part I bought to replace my old idler pulley (the one with the water outlet) is made by GMB. It came with an o-ring (but not round) type seal in the groove where you would normally put RTV or FIPG.
My question is:
Do I just use this to seal it?
Or use the rubber seal AND FIPG?
Or remove the rubber seal and just use FIPG?
Thanks!
Jason
Old Jun 4, 2009 | 01:29 PM
bugs1961's Avatar
Howdy Jason,
If the rubber seal looks like it's a good quality part and fits well, then I'd use it. Don't put FPIG where the seal will go but you could clean the mating surfaces well with acetone or MEK and then coat the outside edge of the idler mating surface with a thin layer of FPIG as a secondary seal. Make sure the FPIG won't squeeze between the rubber seal and the intake before the rubber seal compresses into place as you install the idler. Sounds like an improvement over using FPIG alone.
Bugs
Old Jun 4, 2009 | 05:25 PM
jasonbrink's Avatar
Here is a picture of the idler. GMB Brand. As far as quality of the rubber seal, I really don't kow. I thought I remember seeing a post by someone saying to rip that rubber seal right and use FIPG because theirs leaked just using the rubber seal and no RTV. But I can't find it now. I think I will heed your suggestion and use both.
Thanks Bugs...Again!!
Old Jun 4, 2009 | 05:46 PM
Ardent's Avatar
https://www.yotatech.com/forums/f116...ey-2-a-177592/
That's the thread that says not to use the supplied O-ring. Post # 15.
Old Jun 4, 2009 | 06:52 PM
jasonbrink's Avatar
Thank you very much!
Jason
TJWilly
Jul 31, 2015 02:05 PM
KyleT
Jul 21, 2015 07:54 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
ptb12
Jul 5, 2015 01:49 PM
