AC Evaporator Box
Old Jun 14, 2009 | 07:04 AM
DanStew's Avatar
AC Evaporator Box
I have the avaporator box out of the truck and all of the clips and screws out, but the box will not seperate. IS it glued? Or are there little "tits" holding the halves together right under wwhere the clips were? I do not want to bust the box, just want to make sure there is nothing holding it too that i wil snap off.
Thanks
Old Jun 14, 2009 | 07:12 AM
elblako91's Avatar
hmm if you took all the screws out and all the clips then it should seperate. Mine came apart without problem. Double check all your screws and clips. Might have missed one.
Old Jun 14, 2009 | 07:22 AM
Duelertoyota4x4's Avatar
i just did mine the other day.
Its just kinda stuck together. I gently pried my a little starting at the holes where the tubes exited. And once it was started...it came apart nicely.
Old Jun 14, 2009 | 07:34 AM
DanStew's Avatar
Thanks!! It was just a bit "sticky". There was some kind of sealent holding it together. Now the battle is to get the line from th eevaporator to the expansion valve to come off. THe connection is tight and i know it will slip and i will put the wrench throguh the radiator
Old Jun 14, 2009 | 08:42 AM
DanStew's Avatar
Well it is back together, now just going after the other o-rings and do the dryer.
Thanks Again!
Old Jun 14, 2009 | 02:05 PM
i gutted mine completely and sealed up the holes...A/C delete..lol
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Badlander
Oct 10, 2015 08:05 PM
mreagen
Oct 5, 2015 04:27 PM
voiddweller
Oct 2, 2015 07:47 AM
