Clutch installation - backwards?
Old Jun 14, 2009 | 05:15 AM
cchinny's Avatar
Installing autozone clutch on my 1989 22re 4runner. Is there a certain way the disc has to go in and how do I know which way is the right way? I noticed one side is flatter the other side has the inner disc with the springs is raised. Also, in another post I asked about oil in the bellhousing. I did the rear seal, should I do the front trani seal also?
Thanks!
Old Jun 14, 2009 | 05:29 AM
ozziesironmanoffroad's Avatar
autozone clutch? why autozone? why not OE?
and while u have the tranny down, id do all seals down there, just for peace of mind.
Old Jun 14, 2009 | 11:47 AM
cchinny's Avatar
Autozone is Duralast and it was because I was cheap and in a rush. Has a lifetime warranty on it. I'll do the front trani seal while I have it out. Did the rear main already. Still need advice on the clutch disc.
Old Jun 14, 2009 | 11:56 AM
INFINITY's Avatar
i am pretty sure the disk will only fit one way. with the disk middle side with the step goes out towards the pressure plate.
Old Jun 14, 2009 | 12:02 PM
cchinny's Avatar
Great. Thanks. That's the way I have it. Just need to do the trani seal and try go tet the transmission back in now.
Old Jun 14, 2009 | 03:28 PM
Dirt Driver's Avatar
Because the Duralast clutch is likely made by the same company that made the OEM. I got a Duralast for my truck a few years ago that was made by Valeo, the same company that makes many of Ford's passenger car clutches. I don't know if Luk made the factory Toyota parts, but that's what came out of my truck.
Regarding the orientation of the disc, it should be marked on one side. If not, generally the flattest side goes toward the flywheel and the taller side toward the pressure plate like cchinny said.
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
rchavis
Jul 27, 2015 07:41 AM
1996Taco
Jul 20, 2015 12:02 AM
