rubbery foam stuff
Old Jun 11, 2009 | 09:27 AM
machine23's Avatar
rubbery foam stuff
im tearing up my carpet right now and im running into a couple of things.
1. what is everyone using to remove that foam rubber stuff underneath the carpeting?
2. how do i disconnect the rear passenger heater core from the floor? or is that only possible from underneath?
Old Jun 11, 2009 | 09:30 AM
Lumpy's Avatar
The rubbery foam stuff...I was able to just rub most of it off. The majority of mine came off with the carpet. The rest i just kinda rubbed off with my thumb and palm.
As for the heater I'm not real sure, I left it connected and worked around it. I didn't want to mess with it because the lines are starting to seep a bit already and I didn't want to replace them yet.
Old Jun 11, 2009 | 11:14 AM
Gizler00's Avatar
Brake Kleen always works well to get stuff like that off. Just spray it on let it soak in and then you should be able to scrape it off.
Old Jun 12, 2009 | 09:33 AM
machine23's Avatar
thanks guys for the help. i used wd40. slightly easier to breathe with wd40 than brakleen
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
moparbay
Oct 6, 2015 09:24 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
