toytec lift madness!HELP!
Old Jun 8, 2009 | 03:50 PM
alexcarey's Avatar
ok so now its a rear AAL and front BS spacers. i am having lots of touble getting the bj and spacer lined up with the upper control arm. what the hell is going on?! i know lots of people have done these 2in lifts. how did you get the front back together???please help today is my only day off and i gotta get it back together
Old Jun 8, 2009 | 04:30 PM
Tubbyfatty's Avatar
You have to grind the bottom side of the A arm. Where it bolts up.
http://sdori.com/SDORI_4WD_Spacer_Install.html
Old Jun 8, 2009 | 07:14 PM
alexcarey's Avatar
I did that. What I meant was the steering knuckle wouldn't go unough
Upright to put it in place but I took care of that with a swift kick :Grin:
Old Jun 8, 2009 | 07:26 PM
abecedarian's Avatar
so the lower control arm was keeping the upper ball joint from dropping far enough?
yeah, it happens. disconnecting the sway-bar mounts from the frame gives the lower control arm a little extra down travel and makes it easier to get the upper bj in to place.
suppra87
Jul 15, 2021 05:15 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
AkitaDog
Sep 3, 2015 09:01 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
