injectors not truning on
Old Jun 14, 2009 | 08:32 AM
jdanglesyota's Avatar
Exclamation injectors not truning on
has any one ever had a problem with the injectors not firing? or a good wiring diagram with all the components involved with that system? the truck has been siting for 2-3 years the grounds are good that go to the engine but the only wiring diagram i have isn't vary good. any ideas would be great. thanks
Old Jun 14, 2009 | 11:49 AM
myyota's Avatar
Have you checked the fuses to see if there good ?, also check the solenoid resistor, if its bad your truck won`t start.
Old Jun 15, 2009 | 01:46 PM
where is the solenoid resistor? all the fuses r good.
Old Jun 15, 2009 | 01:49 PM
4Crawler's Avatar
Usually passenger side fender, looks like a big aluminum heat sink (with the cooling fins).
Old Jun 16, 2009 | 02:44 AM
OK thanks so much. i had a feeling hatthing had sumthing to do with it.
Old Jun 16, 2009 | 06:15 AM
abecedarian's Avatar
Also check that you have spark: if the plugs aren't firing, that could indicate an issue with the distributor or igniter, either one of which can cause the injectors to not fire, since the injector firing is based on a signal that is generated by the pickup coil in the distributor and relayed to the ECU through the igniter.
Old Jun 16, 2009 | 05:37 PM
myyota's Avatar
When the solenoid resistor went bad on my 4Runner It would only try and start if carb cleaner was sprayed into the throttle body, at first i didn`t know what the solenoid resistor was or what it did, but after checking and trying everything else, i had an extra solenoid resistor that i decided to try just for the heck of it, and to my suprise my truck started right up on the first try.
Old Jun 17, 2009 | 04:36 PM
no luck. i replaced the resitor with a good one and still in the same spot. i have spark the truck will run if you dump fuel down the in take. i tryed puting another ground on it and still nothing. i guess i i can do is chase the wires
Old Jun 17, 2009 | 05:10 PM
4Crawler's Avatar
May be a broken splice inside the injector wiring harness:
Old Jun 17, 2009 | 05:24 PM
could be. thanks for the help and the diagram
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
themightykhoner
Sep 18, 2015 02:28 AM
larrys93pickup
Sep 17, 2015 07:05 PM
Kytowboater
Sep 17, 2015 11:17 AM
