89 22re fuel problem NO START HELPPPP!!
Old Jun 7, 2009 | 03:32 PM
coco-customs's Avatar
Trying to make a long story short. .I swapped a 89 22re into a 83 pickup and im using the harness and everything that came off the motor. the motor ran great when removed. I have everything hooked back up, and when I crank the motor it dosent start . So heres where im at, I have strong spark at all cylinders, I checked my injectors with a noid light and there all flashing, I installed a inline fuel pump rated at 50psi and its pumping good gas. Now when I spray starting fluid in the intake It starts right up and runs off that. One of my questions is I checked my fuel pressure at the fuel rail and I also have 50psi there. Is that right?? Other then that im stumped an REALLY would like some advice.
Old Jun 7, 2009 | 07:10 PM
myyota's Avatar
Make sure all of the grounds are hooked up, and check your fuses, if everything checks out then check the solenoid resister and see if its good. I had a problem similar to this on my 86 4Runner, i had fuel and spark and all the relays checked out, but no start. It would try and start if i sprayed carb cleaner in the throttle body but no start, so i had a solenoid resister laying around and decided to try it as a shot in the dark that it would work, and to my suprise my truck started after i replaced it.
Old Jun 7, 2009 | 07:54 PM
abecedarian's Avatar
After trying to start, how do the spark plugs look? Are they wet / fouled or dry?
50 PSI is a tad high for fuel pressure- should be about 38-45 PSI. Considering you do have pressure in the rail, I wonder if the excessive pressure might be holding the injectors closed...?
Old Jun 7, 2009 | 08:26 PM
All grounds seem to be good. When I pulled the plugs they were a little black but they were a little old to start so I dont know if they got worse with my problem. The weird thing is they also had a hint of gas smell on them. I was also wondering if to much pressure would not alow my injectors to open. but everything else checks out like I said, a little starting fluid in the intake and it starts and runs great for a couple seconds. Also another thing, everytime I hit the key the motor pops once real quick like it wants to fire, then just cranks.
Old Jun 7, 2009 | 08:35 PM
Given that, change your plugs and check your timing.
Old Jun 8, 2009 | 09:16 AM
Timings good. Like I said it ran great when removed. Also I cleaned the plugs real good but they also worked good when the motor was removed. I think i've narrowed it down to an electrical/injector issue. how do I check the solenoid resister??
puffin04
Jul 10, 2015 09:17 PM
bigblue82
10
Jul 6, 2015 08:27 AM
jmc88runner
Jun 18, 2015 03:39 PM
Dennis140
Jun 17, 2015 10:37 AM
Old Red 94
Jun 16, 2015 08:32 PM
