Fuel Pulse Damper ?
Old Jun 7, 2009 | 05:49 PM
myyota's Avatar
Fuel Pulse Damper ?
Can someone tell me were this part is located on my 86 4Runner ?, and what exactly it does, is it an expensive part ?, a picture would be a big help so i know what im looking for.
Old Jun 7, 2009 | 06:23 PM
BLKNBLU's Avatar
#23270 at the front of the fuel rail
http://www.toyodiy.com/parts/p_U_198...MDEA_2211.html
Available here
http://www.rockauto.com/catalog/x,ca...,parttype,6120
or not much more for OEM. Gahh! The link won't hold info. You'll have to paste this part # in 23270-35010
http://www.trademotion.com/partlocat...&siteid=214074
Not exactly sure what it does. I guess as the name implies, dampens pulsations in the fuel supply. My OEM was plastic and cracked after 20+ years. Also importantly, the gasket is a one time use item though I think I got away with re-use once, but not twice. That is more likely a dealer only item, thats where I ended up.
Edit. Click the "more info" button on the Rock Auto link for a pic
Old Jun 7, 2009 | 06:44 PM
myyota's Avatar
Thats the information i needed.
Thanks
Old Jun 8, 2009 | 12:31 PM
moonbase1's Avatar
Spend the few extra bucks and get it from the dealership! Trust me.... I got one from NAPA and one from Carquest and took them both back! The one from NAPA actually broke while I was installing it. The factory dampener is of a MUCH higher quality, you can see just by looking at it.
Old Jun 8, 2009 | 02:30 PM
854x4's Avatar
I did some research on this a while back and I found out that the damper is only on the 84-88 22re models. On the 89-95 models it is just a banjo bolt so maybe you can replace your damper with a banjo bolt from a later model truck?
Old Apr 24, 2010 | 04:25 PM
Yotapowa's Avatar
Sorry to bring back to life an old thread!
Can somebody tell/show me where to find the fuel pulse damper on an 86 22RE? I believe this may be the problem on my truck, but have no idea where to look for this.
THanks
Old Apr 24, 2010 | 05:40 PM
myyota's Avatar
THanks
Its on the front of the fuel rail, look at the fuel rail just below the throttle body and you will see it.
Old Apr 24, 2010 | 05:46 PM
Yotapowa's Avatar
gotcha thankyou. if its leaking, i just need to tighten the screw on it, correct?
Old Apr 24, 2010 | 09:08 PM
BLKNBLU's Avatar
Maybe. They have a copper gasket that is supposed to be a one time use. I got away with using mine twice, but no go the third time. Toyota part # 9043017002. Just under 2 bucks. Good luck.
Old Apr 26, 2010 | 12:48 AM
Yotapowa's Avatar
So i discovered teh pulse damper, and removed the plastic cap over it, to find it was leaking an oily substance(should there be oil coming out there???) I have not yet tightened the screw on the inside, im going for a new gasket tomorrow. Any advice for properly setting the adjustment?
jashoeuh
Nov 18, 2024 08:08 AM
wafoogalla
Nov 2, 2016 11:02 AM
ripp96
Jul 25, 2015 02:32 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
