- **95 4runner questions**
- blower speed
- Charcoal Canister lines
- Hurray for Upgrades !
- FINALLY! After months and months work....
- DENSO Cap and Rotor - WTFrench cheese?
- She is fixed and looks new
- 22RE Idle Prolems
- Stock rear bumper mounts
- 3vze Got crank, No Start!!!!
- 88 2wd Pick-up front mud flaps..?
- Electrical Problems.....I Think
- 1988 pickup 22re camshaft
- 1986 4Runner - Daily Driver/Project
- Cruise Control
- 94 pickup 22re motor swap PICS
- 1989 Pickup Electrical Problems new starter, new alt, new battery
- Cold start switch
- Fan shroud build and... Don't buy the Spectra CU50 radiator for your 3vze!!!
- Newbie rear diff question w/ pic
- Trucks under-represented at auto shows?
- help! brakes seized
- 4Runner front end swap AC question
- Bolt on aftermarket crossmember?
- 86 Pickup, 22R 5 speed transmission/shifter ?
- 91 V6 4runner has no power?
- 3.0 intake manifold problem
- 22r carb issue (86)
- Need Help!!! Drastic Pulsating Idle 22re
- Driveshaft grinds support
- G54 or W56
- Ifs bad sound passenger side
- Need a part number for this "dust diflector"
- OME/4Crawler Lift- help
- Snow plow from 2nd gen to 3rd gen??
- 3.0 gets hot uphill only
- Electrical Problem, Radio Cuts Out
- Blue/Yellow wire - radio battery - no power
- Timing belt
- 1994 picup brake conversion kit
- Question About OEM Stereo Button Lighting
- Help on diy headlight harness..
- need some help
- 1989 pickup replacing rear main seal
- front ifs 4x isn't working. help!!!
- Axle question
- A/C Choices of substitute for R12/CFC-12
- drove to work got towed home
- passenger seat problem
- 93 3.0
- help with my passenger seat?.
- Could use some help identifying some spare parts.
- 93 4runner 3vze Idle running issues after head gasket repair
- 22re - TPS dead spot and failing smog
- Moog warranty
- Sequence for torquing mains/carrier
- 87 pick up 4 link rear?
- OBD I help on 1993 4x4 pickup
- Flamethrower injector MPG increase
- Over/under drive?
- brass vs aluminum dist cap?
- 22re timing advance
- Inclinometer swap
- 86 4runner Channel Guides Help
- Anyone running an Autozone radiator in their 3vze?
- 22re will start but dies right away
- 2nd Gen 2WD vs 4WD Toyota Frame Questions.
- '86 22re Rough Idle... Vacuum leak?
- Rebuilt 88 3.0 NO Start
- Spare/ gas can mount ideas?
- heater a/c controls
- ac controls
- 88 4runner ac help
- confused about aftermarket intake manifold
- Starts runs 5 sec then stalls...
- Temp gauge moves but always low - tstat replaced with OEM
- ecu bad?
- Distributor Went Bad, Now Runs Rough; Ignitor??
- 91 runner transmission help
- Bell Housing - Flywheel - Starter - Interchangeability
- A/c compressor leak
- 22re Engine Vibration throughout all RPM's
- faint electrical power
- 86 22rte missing
- A seat swap question
- No brakes after caliper/MC/booster swap.
- new tires and rims before spacers... whatcha think???
- 3VZ 91 runner is not moving
- Cel code 41/idle problems
- Seat swap in 91 pickup
- Spare Tire Theft A Consistent Crime In Metro Area
- Front Stablizer bar bushings
- 86 4runner, what do you guys think?
- Anyone do diesel swaps in/near nor cal?
- ZUK Mod Trail Experience?
- 1993 4runner 3.0 diagnostic console
- 71 issues with my Surf spoiler
- Need 22re throttle cable
- 3vze coolant leak
- Transmission swap.
- Timing and tps issue
- 88 4Runner 22RE 4X4 purchase advise
- Gasket for throttle body oval one
- 22 RE stalls only when driving
- 1989 2WD Cannot Install Transmission
- Looking for some information on lift kits
- 22re acting really weird with power surge
- Help!! Tranny problems
- Help!! Trasmission problems e340h
- E340h transmission...help!!
- Oil leak turned out to be much more
- Seat belt retractor is locked up
- 91 22RE code 31 help
- Sick new '95 runner
- Toyota 3.0L V6 3VZE Timing Belt replacement
- loose pink wire
- Rear main leaking, 22RTE
- Too high of gears? 91 4x4 M/T, confused...
- 3vze crankshaft pulley!!!
- 1990 intake manifold reassembly, nuts and bolts and ...
- going to look at a 93 4runner, botched SAS, frame swap....
- Low/ No air flow out the vents
- 87 4 runner SR5 22RE - Transmission done? Or bearing issue?
- Liloscar
- Liloscar truck motor
- 22r or 22re question
- 22r or 22re
- Help me spend $500 on my 87 4Runner
- Oil Leak From Exhaust Manifold Gaskets? Help Please.
- Help me identify this noise please!
- Need help with crack on dash!!!
- 1989 toyota 2wd knocks off and wont crank up now
- Sway bar disconnect vs. CV joints
- Wondering what this white cable is?
- Swap diff or axle?
- Rebuild Questions
- Please help me confim my starter is bad
- Pinion gear play.
- 22RE tick or ping?
- Budget friendly exhaust
- Advice for new guy
- Flamethrower injector review and install writeup - 88 22re
- Ready to give up!!!!!!3.0
- 22rte manual
- Colorado people help!..... your emissions is a bit hardcore
- engine cranks, cam does not spin
- Transmission Fill plug
- front suspension question
- Fuel gauge problems
- Bad vibration!
- Fuel Problem. Won't fire. Fuel Pump confirmed good but no fire on start.
- Auto Trans constant changing gears at 55mph
- Here's the Part Number for the Engine Coolant Temperature (ECT) Plug Housing
- 94 runner 3.0 need fuel tank what fits
- 1991 dog help!
- Front Third Member... New to the game
- been thinkin of a better cold air intake setup...
- 90 4runner, 22re, cutting out WOT, no power, surging
- lighter hack so it works with key off
- 1993 4Runner Truck Antenna Issue
- 89 22re FlameThrower Injector Review
- sucking fuel now 94 3.0 runner
- 1990 4runner 3vze oil cooler ?
- 90 2 door 4runner?
- 93 4runner door handle/lock disassembly?
- Changing Pinion Seal - Crush Sleeve?
- PAIR Valve Hose Noise
- Cold Start Problems
- adjusted timing, now code 21
- Syrus54 - 1992 Toyota Pickup 4WD Issues
- Ball joint spacer install help
- 94 pickup 3.0 starts then instant stalls Help!!!!!
- Factory Sunroof storage?
- Please help noob fix oil leak!! LOTS OF PICS
- Timing Chain Tension Reversed?
- Nishino bushings
- Raptor engines?
- transfercase questions
- Pic Request - quad (4) round headlights on yota
- 22re Re-build, Band-aid, or sell
- Question about changing dash bulbs.
- Bump Stop Replacement 1990 Pickup
- Need help with 3VZ-E
- Flamethrower 3VZE injector review
- New Yota owner/older truck. Would like advice
- 87 4Runner TrueTrac vs Lockright IFS
- My first 4x4, 1987 4runner, 22RE
- Replaced clutch master, and I now have a bigger leak
- Adjusting camber
- Flares or skinny wheels?
- Overdrive Issue
- Anyone have the correct alignment specs?
- advice on 3.4 swap
- Hella Vision Plus H4 Light Conversion
- Dim headlights
- A/C to heater control help
- 3vze Air Intake Deflector Mod
- Wheelhousing for 91 pickup
- Identify that sound... before something goes boom
- Accident - Headlight Replacement Question(s)
- old alarm removal
- "87" 22r idle and running problem
- 95 3vze startup/performance issues
- how do you change the outer outer tie rod on 89.
- how to change stablelizer bushings on 89sr5 4x4 pickup
- Body repair panels
- Half Shaft Install
- Air conditioning
- New Distributor Cap or (old) Plug Wires are Shorting
- JET ECU upgrade
- CNG 22re?
- Advice on checking valve clearances
- Loud Thunking, is it this or that...?
- overheating
- In desperate need of help with power window
- Code 21 and code 52 before and after head gaskets
- what would cause the base timing to change
- Proportional brake valve, 1987 Toyota truck
- Vacuum Problem!!! 93 Toyota Pickup 3VZE
- 93 Runner 3VZE transmission R151?
- help!!!
- 3vz afm adjustment question..
- Speed Sensor Location
- Idle surge, Dieing on road
- Need Help Finding This Part For My 87 Pick up
- Methanol Injection on 3VZ-E?
- my 4runner excersism video
- Quick, Easy, Painless 3vze Intake Plenum and Upper Engine Cleaning and TuneUp
- Fuel Line Replacement
- 90 4runner oil gauge
- Cracked windshield
- Engine removal
- Replacement shackles
- Weird Coolant/Radiator Cap Issue
- 89 4runner fuel problems?
- Help.... Replacing upper control arm bushings
- clutch pedal problems!!!
- Brake Booster Replacement Tips
- light bulbs/ LEDs
- I need a factory service manual '93 T100 3.0 SV-E
- IFS LCA rear brace
- 1990-91 4Runner Dual Spare Tire Modification
- 91 22re pickup fuel pump bypass
- Temperature unit? Clogged radiator hose underneath
- First Toyota purchase
- Power to solenoid valve on carb
- no power and over-heating after reconditioned head
- power issue or transmission issue
- clutch help!
- oil seal leak drivability
