clutch pedal problems!!!
Old Aug 8, 2013 | 05:43 AM
90yota88's Avatar
I just recently did the auto to manual swap and installed new clutch pressure plate and throw out bearing clutch mater cylinder and slave cylinder when I got to let the clutch out it is letting out about an inch off the floor is this normal or what should it be ive bled it a few times and im not getting any air any ideas thanks for all the help!
Old Aug 8, 2013 | 05:48 AM
JasonYota's Avatar
Sounds normal. Did you get your parts to match up with one trans?
Old Aug 8, 2013 | 06:34 AM
90yota88's Avatar
yes I did I bought an entire truck and used the parts but that sounds normal?
Old Aug 8, 2013 | 06:45 AM
JasonYota's Avatar
Yea it sounds normal. Mine grabs close to the floor also. I would think as long as it releases when you press the clutch in its good.
Old Aug 8, 2013 | 07:14 AM
90yota88's Avatar
ok that makes me feel better about it
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
