Transmission Fill plug
Old Aug 15, 2013 | 05:07 PM
1994toyota's Avatar
Hello, I have a 94 toyota pickup with the 5 speed. Was just checking fluids and decided to check the trans fluid. Well 20 minutes later using vise grips the plug is out. Where can I find a new fill plug at? I just vise gripped the old one back in for now. The threads are ok but the head is not. Any info would help thanks.
Old Aug 15, 2013 | 05:37 PM
rworegon's Avatar
Toyota dealer
Auto recycler
Local parts store possibly
Old Aug 15, 2013 | 06:06 PM
SPARKS89's Avatar
Find one at a local junkyard. You have a W56 series transmission and I can't imagine they would change the plug size on those so you should have a wide range of years to work with in finding a replacement. A 15/16" socket should fit what you need.
A little tip for anyone that might need it. Always make sure you can take out the fill plug before removing the drain plug. It sucks to drain the gear oil out and then find out you can't refill it.
Old Aug 15, 2013 | 06:22 PM
1994toyota's Avatar
Haha that would suck if you could not get the fill plug out if you already drained it. I will see if the local junk yard has a toyota.
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
jjrbus
Jul 17, 2015 07:06 AM
mengquis
Jul 13, 2015 10:39 AM
