engine cranks, cam does not spin
Old Aug 15, 2013 | 06:10 PM
edeslaur's Avatar
I'm guessing the engine builder screwed up the woodruff key and 22k miles later, this is what I get. Cherry on top of all the problems from this builder (San Diego Toyota "specialist" shop)
Manual says to pull the head to get to it. I'm between garages, any shortcuts? Seems like it'll be almost as cheap just to rebuild it again, jeez...
How concerned should I be with the condition of the crank or oil pump?
Old Aug 15, 2013 | 06:13 PM
Vexwar's Avatar
what engine you running?
Old Aug 15, 2013 | 06:58 PM
edeslaur's Avatar
Hey, what happened to my sig?!
87 Turbo (22RTE)
Old Aug 15, 2013 | 06:59 PM
edeslaur's Avatar
Ah, posting from mobile doesn't included. I did not know that. Sorry!
Old Aug 15, 2013 | 07:25 PM
Vexwar's Avatar
To see the key for the cam you just need to take of the valve cover. Never did that with a turbo. Should be 4 bolts and a couple wires and a vac or 2. From therd you sjould bd able to have someone crank it while you watch the chain. Heads up you will spray oil
Old Aug 15, 2013 | 07:35 PM
edeslaur's Avatar
The crank side is spinning loose. Engine cranks over, but the cam/chain does not move (pulled the valve cover and checked). Chain is tight, double-roller unit.
Guessing the woodruff key on the crank gear is broken.
I was idling across the parking lot when it died.
Old Aug 15, 2013 | 07:42 PM
snobdds's Avatar
The only thing that turns the cam is the the distributor drive gear at the front of the cam. There is no woodruff key in the drive gear, just a pin. A person really can't mess it up on install. It could also be you broke the roll pin in the distributor and the distributor gear is preventing the drive gear from turning...
Old Aug 15, 2013 | 07:52 PM
SPARKS89's Avatar
[QUOTE=snobdds;52108631] The only thing that turns the cam is the the distributor drive gear at the front of the cam. [QUOTE]
Don't you have that backwards??? The cam is driven by the timing chain which is driven by the crank. The gear on the front of the camshaft is what drives the distributor gear.
If the engine is turning over, but the chain isn't moving and therefore the cam and distributor aren't turning either, then the problem is down at the crank.
Old Aug 15, 2013 | 07:54 PM
edeslaur's Avatar
The cam and cam gear are not turning when the engine is cranked. If the cam and cam gear do not turn, the distributor does not turn (and it does not).
The gear on the crank is obviously not doing its job. According to my manual, it has a woodruff key. I'm guessing that it's busted.
Based on that... what's the easiest way to fix it?
Old Aug 15, 2013 | 08:09 PM
YotaWoRx's Avatar
Pull the timing cover. fsm says to pull the head first, but it can be done without. There is a bolt that goes through the head and into the timing cover. It's hidden under a pool of oil so remove it before u drive yourself crazy trying to break the cover loose!
Old Aug 15, 2013 | 08:12 PM
Vexwar's Avatar
Pull off the oil pump to check the key. Should only take like 15 mins with a air gun
Old Aug 15, 2013 | 08:13 PM
edeslaur's Avatar
That's the kind of tip I was looking for, thank you. I'm between garages - how big a deal is it to do, effectively on the side of the road?
Old Aug 15, 2013 | 08:19 PM
edeslaur's Avatar
And... this is NOT a zero clearance motor, right? If this pretzeled a valve...
Old Aug 15, 2013 | 08:24 PM
edeslaur's Avatar
Ok, I'm officially, probably, screwed:
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
CAUTION: The 22R line of engines are an interference style engine.
Meaning if the valves are open when a piston is in the up position they will collide.
Therefore you must be VERY careful and keep the cam gear and crank perfectly aligned.
Old Aug 15, 2013 | 08:27 PM
SPARKS89's Avatar
It sucks when you have to remove your front diff to gain access to where you can pull the oil pan. You can still do it if you have all the tools and a remote power supply to run your impact gun, but it's still gonna suck doing it on the side of the road. Don't stick your legs out too far when you're crawling around under the truck!
Old Aug 15, 2013 | 08:43 PM
edeslaur's Avatar
LOL. I'll call some shops tomorrow, but I think it's going back on a tow truck. I've picked up my M3... it'll have to do.
Old Aug 15, 2013 | 08:44 PM
Vexwar's Avatar
I didn't think they were i could be wrong though. i know it took me a few attempts to get my timing right on my 22re and it runs like a champ now
Old Aug 15, 2013 | 10:16 PM
edeslaur's Avatar
Mine's a turbo with dished pistons, so I may be OK. Checking on the RTE board if they feel it's a concern. I'm more ready to throw in a new motor, probably from Putney's or LCE, just so I don't have to worry about things like this happening 200 miles from civilization.
Old Aug 15, 2013 | 10:18 PM
edeslaur's Avatar
Oh, and DOA since they're moving to AZ. I have their turbo cam in here, and it's been great. Much better than the Crane/TRD/Toyota Stage II that was in there.
Old Aug 16, 2013 | 09:32 AM
vital22re's Avatar
totally a bro
Please read up on the DOA reviews. Not a very good place
